I have found this entry in /etc/passwd:
debian-tor:x:117:123::/var/lib/tor:/bin/false
But there is no /var/lib/tor folder. This is on a server not a desktop.
This is a user that is created by installing tor or tor-browser.
For instance, if you look into postinst script of tor package, you'll see:
# checking debian-tor account
uid=getent passwd debian-tor | cut -d ":" -f 3
home=getent passwd debian-tor | cut -d ":" -f 6
if there is the uid the account is there and we can do
the sanit(ar)y checks otherwise we can safely create it.
if [ "$uid" ]; then
if [ "$home" = "/var/lib/tor" ]; then
#echo "debian-tor homedir check: ok"
else
echo "ERROR: debian-tor account has an unexpected home directory!"
echo "It should be '/var/lib/tor', but it is '$home'."
echo "Removing the debian-tor user might fix this, but the question"
echo "remains how you got into this mess to begin with."
exit 1
fi
else
adduser --quiet
--system
--disabled-password
--home /var/lib/tor
--no-create-home
--shell /bin/false
--group
debian-tor
fi
for i in lib log; do
if ! [ -d "/var/$i/tor" ]; then
echo "Something or somebody made /var/$i/tor disappear."
echo "Creating one for you again."
mkdir "/var/$i/tor"
fi
done
which restorecon >/dev/null 2>&1 && restorecon /var/lib/tor
chown debian-tor:debian-tor /var/lib/tor
chmod 02700 /var/lib/tor
which restorecon >/dev/null 2>&1 && restorecon /var/log/tor
chown debian-tor:adm /var/log/tor
chmod 02750 /var/log/tor
But this user is not removed when you uninstall tor. I don't see anything that removes the user in prerm, or postrm script.
So it means that you have tor installed, or installed it previously.
There is no harm in having some extra user in your system, but you can remove it if you like.
You can remove the user by running
sudo deluser debian-tor
