After some investigation, I found this thread that had a solution. I downgraded my nvidia driver to 435 - and it solved the issue, I can now use HDMI screen, but my laptop screen now is black and unusable.
Ubuntu 20.04 does not recognize second monitor
I downgraded to nvidia-435 driver, and it worked fine. Something didn't >get thoroughly vetted/tested with the 440 drivers. Just downgrade for now >and see if that helps.
Does anyone know how can I connect my laptop screen again?
my xrandr:
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 476mm x 268mm
   1920x1080     60.00*+  59.94    50.00
   1680x1050     59.95
   1440x900      59.89
   1280x1024     75.02    60.02
   1280x960      60.00
   1280x720      60.00    59.94    50.00
   1024x768      75.03    70.07    60.00
   800x600       75.00    72.19    60.32    56.25
   720x576       50.00
   720x480       59.94
   640x480       75.00    72.81    59.94    59.93 ```
When I run sudo prime-select intel my laptop screen works and the HDMI doesn't, but when I run sudo prime-select nvidia my laptop screen doesn't work and the hdmi does.
Any ideas why is this? And how to have both of them working at the same time?
Kulfy
  • 18,154
Actually, what happend to me was that for some reason, when I saved the nvidia-settings to the X file (/etc/X11/xorg.conf) configs only for the external monitor were added. As a result, after a reboot, only the external monitor was detected.
The NVIDIA X Server Settings software can be opened by running 'nvidia-settings' on the terminal.
As suggested by Kulfy, the solution was to delete /etc/X11/xorg.conf and do a reboot. Everything works again as expected.
See this Internal laptop screen not detected when using Nvidia driver
Emanoel
  • 61
