After a power cycle, I'm unable to see my ethernet interfaces in ifconfig with the following netplan configuration. ethMine shows up in ip link show, but is not upped.
$ cat /etc/netplan/01-netcfg.yaml
network:
  version: 2
  renderer: networkd
  ethernets:
    enp38s0f1:
      addresses: [192.168.1.21/24]
      match:
        macaddress: 80:fa:5b:xx:xx:xx
      set-name: ethMine
      nameservers:
        addresses: [8.8.8.8, 8.8.4.4]
      optional: true
  vlans:
    ethMine.200:
      link: ethMine
      addresses: [192.168.1.121/24]
  wifis:
    wlx7ca7b0bbf9f1:
      addresses: [10.10.10.15/24]
      gateway4: 10.10.10.1
      nameservers:
      access-points:
        "myssid":
          password: "mypasswd"
  • On Ubuntu desktop.
  • There are no other netplan configs.
  • /etc/network/interfaces is commented out
$ dmesg | grep ethMine
[    2.881002] r8169 0000:26:00.1 ethMine: renamed from enp38s0f1
On reboot, I see ethMine in ip link show, but it is not up and visible in ifconfig. ethMine.200 does not exist.
systemd logs:
Jul 20 12:47:08 lappy systemd[1]: Starting Network Service...
Jul 20 12:47:08 lappy systemd-networkd[383]: Enumeration completed
Jul 20 12:47:08 lappy systemd[1]: Started Network Service.
Jul 20 12:47:08 lappy systemd-networkd[383]: enp38s0f1: Interface name change detected, enp38s0f1 has been renamed to ethMine.
Jul 20 12:47:08 lappy systemd-networkd[383]: wlan0: Interface name change detected, wlan0 has been renamed to wlx7ca7b0bbf9f1.
Jul 20 12:47:08 lappy systemd-networkd[383]: wlx7ca7b0bbf9f1: IPv6 successfully enabled
Jul 20 12:47:08 lappy systemd-networkd[383]: lo: Link is not managed by us
Jul 20 12:47:08 lappy systemd-networkd[383]: ethMine: Link is not managed by us
sudo systemctl restart systemd-networkd causes ethMine to be upped, but still no vlan with logs:
l 20 12:52:02 lappy systemd[1]: Stopping Network Service...
Jul 20 12:52:02 lappy systemd[1]: Stopped Network Service.
Jul 20 12:52:02 lappy systemd[1]: Starting Network Service...
Jul 20 12:52:02 lappy systemd-networkd[5975]: wlx7ca7b0bbf9f1: Gained IPv6LL
Jul 20 12:52:02 lappy systemd-networkd[5975]: Enumeration completed
Jul 20 12:52:02 lappy systemd[1]: Started Network Service.
Jul 20 12:52:02 lappy systemd-networkd[5975]: wlx7ca7b0bbf9f1: IPv6 successfully enabled
Jul 20 12:52:02 lappy systemd-networkd[5975]: ethMine: Link is not managed by us
Jul 20 12:52:02 lappy systemd-networkd[5975]: lo: Link is not managed by us
Jul 20 12:52:02 lappy systemd-networkd[5975]: ethMine: IPv6 successfully enabled
Jul 20 12:52:02 lappy systemd-networkd[5975]: ethMine: Link UP
Jul 20 12:52:03 lappy systemd-networkd[5975]: wlx7ca7b0bbf9f1: DHCPv4 address 10.53.189.98/24 via 10.53.189.1
Jul 20 12:52:03 lappy systemd-networkd[5975]: wlx7ca7b0bbf9f1: Configured
netplan.io version in Ubuntu 18.04.4 LTS desktop:
$ dpkg -s netplan.io | grep '^Version:'
Version: 0.99-0ubuntu3~18.04.3
These manual steps work post boot:
sudo ip link set enp38s0f1 down
sudo ip link set enp38s0f1 name ethMine
sudo ip link set ethMine up
sudo ip addr add 192.168.1.21/25 dev ethMine
sudo ip link add link ethMine name ethMine.200 type vlan id 200 sudo ip addr add 192.168.1.121/26 dev ethMine.200 sudo ip link set dev ethMine.200 up
tarabyte
  • 294
/etc/network/interfaces should look like this...
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
/etc/netplan/01-netcfg.yaml should look like this...
network:
  version: 2
  renderer: networkd
  ethernets:
    enp38s0f1:
      addresses: [192.168.1.67/24]
      gateway4: 192.168.1.1
      match:
        macaddress: 80:fa:5b:7d:94:8f
      #set-name: ethMine
      nameservers:
      optional: true
  vlans:
    ethMine.200:
      link: enp38s0f1
      addresses: [192.168.1.167/24]
  wifis:
    wlx7ca7b0bbf9f1:
      nameservers:
      access-points:
        "myssid":
sudo netplan --debug generate
sudo netplan apply
reboot
heynnema
  • 73,649
