I recently upgraded from 16.04 to 18.04.4 LTS, and now want to upgrade again to 20.04 LTS using
sudo do-release-upgrade -d
The process fails with an error message about ppas, but the log files show that the problem has to do with ubuntu-standard and lsof conflicts. It appears that it can't resolve the conflict between lsof:amd and lsof:i386. I tried remove these and reinstalling them, but nothing worked yet.
Is there anything I can do, or should I wait and hope this gets resolved by the package maintainers?
Starting pkgProblemResolver with broken count: 1
Starting 2 pkgProblemResolver with broken count: 1
Investigating (0) ubuntu-standard:amd64 < 1.417.4 -> 1.450.1 @ii umU Ib >
Broken ubuntu-standard:amd64 Depends on lsof:amd64 < 4.89+dfsg-0.1 | 4.93.2+dfsg-1 @ii ugR >
Considering lsof:amd64 0 as a solution to ubuntu-standard:amd64 2
Added lsof:amd64 to the remove list
Fixing ubuntu-standard:amd64 via keep of lsof:amd64
MarkKeep lsof:amd64 < 4.89+dfsg-0.1 | 4.93.2+dfsg-1 @ii ugR > FU=0
Investigating (0) lsof:amd64 < 4.89+dfsg-0.1 | 4.93.2+dfsg-1 @ii ugH Ib >
Broken lsof:amd64 Conflicts on lsof:i386 < none -> 4.93.2+dfsg-1 @un umN Ib >
Considering lsof:i386 4 as a solution to lsof:amd64 0
Re-Instated lsof:amd64
Investigating (1) lsof:i386 < none -> 4.93.2+dfsg-1 @un umN Ib >
Broken lsof:i386 Conflicts on lsof:amd64 < 4.89+dfsg-0.1 -> 4.93.2+dfsg-1 @ii ugU Ib >
Considering lsof:amd64 0 as a solution to lsof:i386 4
Conflicts//Breaks against version 4.89+dfsg-0.1 for lsof but that is not InstVer, ignoring
Fixing lsof:i386 via remove of lsof:amd64
MarkDelete lsof:amd64 < 4.89+dfsg-0.1 -> 4.93.2+dfsg-1 @ii ugU Ib > FU=0
Investigating (1) ubuntu-standard:amd64 < 1.417.4 -> 1.450.1 @ii umU Ib >
Investigating (1) lsof:amd64 < 4.89+dfsg-0.1 | 4.93.2+dfsg-1 @ii ugH Ib >
Removing lsof:amd64 rather than change lsof:i386
MarkDelete lsof:amd64 < 4.89+dfsg-0.1 | 4.93.2+dfsg-1 @ii ugH Ib > FU=0
Investigating (2) ubuntu-standard:amd64 < 1.417.4 -> 1.450.1 @ii umU Ib >
Investigating (2) lsof:amd64 < 4.89+dfsg-0.1 | 4.93.2+dfsg-1 @ii ugH Ib >
Considering lsof:i386 4 as a solution to lsof:amd64 2
Investigating (3) ubuntu-standard:amd64 < 1.417.4 -> 1.450.1 @ii umU Ib >
Considering lsof:amd64 4 as a solution to ubuntu-standard:amd64 2
MarkKeep ubuntu-standard:amd64 < 1.417.4 -> 1.450.1 @ii umU Ib > FU=0
Reinst Failed because of lsof:amd64
Removing ubuntu-standard:amd64 rather than change lsof:amd64
DEBUG The package 'ubuntu-standard' is marked for removal but it's in the removal blacklist
ERROR Dist-upgrade failed: 'The package 'ubuntu-standard' is marked for removal but it is in the removal blacklist.'
EDIT: as requested, here is the output of apt-cache policy ubuntu-standard lsof lsof:i386
ubuntu-standard:
Installed: 1.417.4
Candidate: 1.417.4
Version table:
*** 1.417.4 500
500 http://ca.archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages
100 /var/lib/dpkg/status
1.417 500
500 http://ca.archive.ubuntu.com/ubuntu bionic/main amd64 Packages
lsof:
Installed: 4.89+dfsg-0.1
Candidate: 4.89+dfsg-0.1
Version table:
*** 4.89+dfsg-0.1 500
lsof:i386:
Installed: (none)
Version table:
4.89+dfsg-0.1 500
500 http://ca.archive.ubuntu.com/ubuntu bionic/main i386 Packages
I also tried upgrading to 19.10 as an intermediate step, but this same lsof problem is blocking it.
