I want to copy everything in root / to my external hard disk before I upgrade my OS so I'll have everything just in case something goes wrong. Is the following the most appropriate command for it?
username@machine:/$ sudo cp -r . /media/username/TOSHIBA\ EXT/root_copy/
Eliah Kagan
  • 119,640
scribe
  • 680
5 Answers5
13
To add to what P.P has said, you don't really want to copy every directory. I use tar to backup everything that I need, and "exclude" the directories I don't need. The command basically goes tar (options) BACKUP-FILENAME TARGET. If you run the following command it should do the trick.
sudo tar -cvpzf /media/username/TOSHIBA\ EXT/root_copy/root-copy.tar.gz --exclude='/mnt' --exclude='/run' --exclude='/proc' --exclude='/sys' --exclude='/media' --exclude='/dev' --exclude='/lost+found' --exclude='/tmp' --exclude='/boot' --exclude=".*lost+found" / 2> /root/tar-errors.txt
I know it looks like a lot, but tar is going to create a backup at /media/username/TOSHIBA\ /EXT/root_copy/. The file name is root-copy.tar.gz. It will exclude each of the directories that I have mentioned with --exclude, and lastly it will dump any errors that occur in a file named /root/tar-errors.txt.
Another benefit to using tar this way, is that the backup file will be a "zipped tarball". It's essentially a compressed archive so you will save space on your external drive.
I am sure there are more simple ways of doing this but I have always used this method to backup my systems.
terdon
  • 104,119
Gordster
  • 1,700
Consider imaging the disk instead of making just a copy of files. There's more than just files that can get messed up during an upgrade: EFI system partition, boot sectors etc.
I'd recommend Clonezilla. It's user-friendly and reliable. They have their dedicated boot disk. Some rescue disks provide it too (eg. GRML) and you can install it on Ubuntu Live CD.
Clonezilla images aren't browseable, but can be used to easily restore entire disk to previous condition.
Some people could suggest using dd to create a raw image. It's also a valid approach and resulting files would be browseable, but they would take as much space as your entire partition size. Meanwhile Clonezilla uses partclone under the hood, which only copies actually used disk space and ignores free space unlike dd. Clonezilla will also compress images by default.
gronostaj
  • 750
Yes, if you want to copy everything under /, then you can do:
sudo cp -r / media/username/TOSHIBA\ EXT/root_copy/
But, before proceeding... you need to be aware that you don't really want to copy everything under / :)
You typically only need to copy your data; not all the OS binaries, installed applications, configuration files, etc. Which is what the about command would do.
If OS upgrade goes bad, it's not going to be straightforward to "copy over" everything. If you had your data, you can simply reinstall the OS and copy back the data from the external disk/medium.
Also, if you have set up other partitions than the one you have the OS installed and keep the data there, then you may not need to copy externally at all. You can keep your data in a separate partition. If the OS reinstall goes bad, you can just wipe that partition and reinstall the OS without touching the other partition where you kept the data.
P.P
  • 1,121
rsync is better IMO that tar or cp
if you have your sshkeys setup, and are going to another system: nohup rsync-r /* user@destination:/ARCHIVE_DESTINATION
else rsync -r /* user@destination:/ARCHIVE_DESTINATION
If local rsync -r /* /mnt/ARCHIVE_DESTINATION
I find it much easier to mount the root device on another path and then use cp (or even better rsync). This way I do not need to worry about excluding /dev/disk, /run, /proc etc.
For example:
    eval $(findmnt --pairs --target /)
    sudo mount -t ${FSTYPE} --options ${OPTIONS} --source ${SOURCE} --target /mnt/
    sudo cp -r /mnt/ /media/username/TOSHIBA\ EXT/root_copy/
The first line creates the following environment variables in my case:
    TARGET="/" SOURCE="/dev/sda8" FSTYPE="ext4" OPTIONS="rw,noatime,errors=remount-ro"
These are used to mount the root device again in /mnt. Alternatively, you can use sudo mount --bind / /mnt (I am not sure if there is a difference between the two solutions).
As others have noted, there are things in / that you may not need to backup so it would make sense to exclude them anyway. My solution is useful when you want to copy everything in the partition so you could in principle even boot from the external device (assuming efi, boot, etc are also copied / found somewhere upon boot).
Luca Citi
  • 319
