I've posted the same thing in Ubuntu Forums and Steam community but not found a solution.
sudo apt update followed by sudo apt upgrade leads to the following:
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages have unmet dependencies.
steam:i386 : Conflicts: steam-launcher but 1:1.0.0.64 is to be installed
Conflicts: steam-launcher:i386
steam-devices : Conflicts: steam-launcher but 1:1.0.0.64 is to be installed
E: Broken packages
I don't know if there's any connection between the two, but software updater works perfectly fine.
Steam also updates upon launch as per usual.
When I run sudo apt update I'm told there are 22 packages with requiring upgrades so I'm hopeful of finding a fix.
I've also run:
sudo apt-get install unattended-upgrades
sudo dpkg-reconfigure unattended-upgrades
But nothing happened.
Thanks in advance.
*Version info - Ubuntu 20.04 LTS and Steam API: v020 Package versions: 1591251555
