So I set up a virtual machine with Ubuntu Mate 20.04 and because I wanted to try it out, I set it up to use ZFS. I use a disk size of 10GB and the installer decided to set up my bpool to have a capacity of 480M. However df -h shows
bpool/BOOT/ubuntu_cub7km                          118M   92M   26M  78% /boot
I have 0 experience with ZFS and don't know what this is all about. I didn't even get one kernel update in without an error that initramfs couldn't write to the disk.
Setting up initramfs-tools (0.136ubuntu6.2) ...
update-initramfs: deferring update (trigger activated)
Setting up linux-firmware (1.187.1) ...
update-initramfs: Generating /boot/initrd.img-5.4.0-40-generic
I: The initramfs will attempt to resume from /dev/sda5
I: (UUID=ff3fca52-c9f0-4369-9aaf-598aa999db8b)
I: Set the RESUME variable to override this.
Error 24 : Write error : cannot write compressed block
E: mkinitramfs failure cpio 141 lz4 -9 -l 24
update-initramfs: failed for /boot/initrd.img-5.4.0-40-generic with 1.
dpkg: error processing package linux-firmware (--configure):
 installed linux-firmware package post-installation script subprocess returned error exit status 1
How can I expand that partition? Normally I'd just run gparted and move the sizes about a little, but zfs is supposed to be all advanced and stuff. I tried enabling autoexpand for bpool, but the issue persisted. I don't know where the remaining ~400MB space for that pool went either.
As a workaround I moved the initfs image file to my home directory and ran apt upgrade again, which did generate the new initramfs file without issue. But that seems dangerous and unnecessary.
Edit
I have reinstalled the virtual machine to use a traditional ext4 file system. Thus I can not try out any answers.
FalcoGer
  • 925
I was getting a "similar" error after install a few packages, similar as I am not running ZFS, but same error message. I search and found your issue. Here is my error (see below). I was able to get fix by following answer here, New to Linux, I'm getting this recurring error "ERROR "update-grub" returned an error: exit status 1 " please advise
TLDR; /boot was 100% full, cleaned out with sudo apt clean;sudo apt auto-remove, update-initramfs was run as part of sudo apt auto-remove, and was successful.
sudo apt-get install libgtk2.0-0 libgtk-3-0 libnotify-dev libgconf-2-4 libnss3 libxss1 Reading package lists... Done Building dependency tree Reading state information... Done libgtk2.0-0 is already the newest version (2.24.32-4ubuntu4). libnotify-dev is already the newest version (0.7.9-1ubuntu2). libxss1 is already the newest version (1:1.2.3-1). libgconf-2-4 is already the newest version (3.2.6-6ubuntu1). libgtk-3-0 is already the newest version (3.24.20-0ubuntu1). libnss3 is already the newest version (2:3.49.1-1ubuntu1.2). The following packages were automatically installed and are no longer required: libllvm9 linux-headers-5.4.0-29 linux-headers-5.4.0-29-generic
linux-image-5.4.0-29-generic linux-modules-5.4.0-29-generic
linux-modules-extra-5.4.0-29-generic Use 'sudo apt autoremove' to remove them. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. 1 not fully installed or removed. After this operation, 0 B of additional disk space will be used. Do you want to continue? [Y/n] Y Setting up initramfs-tools (0.136ubuntu6.2) ... update-initramfs: deferring update (trigger activated) Processing triggers for initramfs-tools (0.136ubuntu6.2) ... update-initramfs: Generating /boot/initrd.img-5.4.0-40-generic Error 24 : Write error : cannot write compressed block E: mkinitramfs failure cpio 141 lz4 -9 -l 24 update-initramfs: failed for /boot/initrd.img-5.4.0-40-generic with 1. dpkg: error processing package initramfs-tools (--configure): installed initramfs-tools package post-installation script subprocess returned error exit status 1 Errors were encountered while processing: initramfs-tools E: Sub-process /usr/bin/dpkg returned an error code (1)
Phil
  • 27
