17
Hi everyone and first of all, thanks for your attention - I appreciate it!
Here my problem. I'm new to linux, although I'm a web programmer so command line doesn't look weird to me, and I'm now running Xubuntu. I have made several configurations and installations and it's now working fine, except for this weird thing: terminal window and firefox browser are launching as soon as I log into my account. Does anybody know how such thing could be happening?
I have rebooted several times, logged in/off as well, but both terminal and firefox window come up automatically every time I start a session.
Has anybody run into this before? How can i find a solution to make those apps NOT start on startup?
Thanks again! Hope someone can help me hehe
prubini87
  • 423
There are two possible reasons why the application is started: It is saved in the last session or it is listed in the auto started applications. Follow 1 of the two steps below to get rid of the applications.
  • Start the xfce4-autostart-editor and remove the application(s). You can also manually delete those files in ~/Desktop/Autostart and ~/.config/autostart.
  • Most of the time closing all the applications and save your session when you logout is sufficient. If this doesn't work, remove the content of the ~/.cache/sessions/ directory when you're not logged in. And if you don't want xfce remember every session you should turn off (uncheck) “Automatically save session on logout” in Settings Manager → Sessions and Startup (tab General)
Reference: 1.
desgua
  • 33,215
The first step is to open startup apps and see what is there, might be as easy as that, if those apps are in startup, you can just remove them
Another option to consider is ubuntu tweak, it can help you regulate how things start
Mateo
  • 8,152
dewb
  • 49
