I'm trying to install cURL and then php-curl on Ubuntu 18.04 but it removes Apache when I do this.
$  sudo apt install libcurl4 curl
Reading package lists... Done Building dependency tree Reading state information... Done The following packages were automatically installed and are no longer required: apache2-data libbrotli1 libonig2 libqdbm14 libssl1.0.2 php5-cli php5-json php5-readline Use 'sudo apt autoremove' to remove them. The following additional packages will be installed: php7.2-fpm php7.4-fpm The following packages will be REMOVED: apache2 apache2-bin libapache2-mod-php5 libapache2-mod-php7.2 libapache2-mod-php7.4 libcurl3 php5 The following NEW packages will be installed: curl libcurl4 php7.2-fpm php7.4-fpm 0 upgraded, 4 newly installed, 7 to remove and 12 not upgraded. Need to get 3,191 kB of archives. After this operation, 14.1 MB disk space will be freed. Do you want to continue? [Y/n] y
What am I doing wrong here?
BadHorsie
  • 203
