I found a post with a similar issue for Intel(R) Dual Band Wireless AC 8260 chip set, but cannot follow the recommended steps for Ubuntu 20.04: Intel wireless 8260 - unclaimed network
It suggests compiling the driver for a different pci.id: (IWL_PCI_DEVICE(0x24F3, 0x1130, iwl8260_2ac_cfg)
Now make defconfig-iwlwifi > fails with: Generating local configuration database from kernel ...Kernel version parse failed!
Which driver do I need to use/modify for Ubuntu 20.04?
Diagnostics:
arnulf@Ubuntu-Latitude-E5270:~$ sudo modprobe iwlwifi
arnulf@Ubuntu-Latitude-E5270:~$ dmesg | grep iwl
[    3.180549] iwlwifi 0000:01:00.0: Found debug destination: EXTERNAL_DRAM
[    3.180551] iwlwifi 0000:01:00.0: Found debug configuration: 0
[    3.181174] iwlwifi 0000:01:00.0: loaded firmware version 36.77d01142.0 op_mode iwlmvm
[    3.259955] iwlwifi 0000:01:00.0: Detected Intel(R) Dual Band Wireless AC 8260, REV=0x208
[    3.268283] iwlwifi 0000:01:00.0: Applying debug destination EXTERNAL_DRAM
[    3.269298] iwlwifi 0000:01:00.0: Allocated 0x00400000 bytes for firmware monitor.
[    3.351006] iwlwifi 0000:01:00.0: base HW address: 34:f3:9a:a0:92:ae
[    3.424863] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[    3.671817] iwlwifi 0000:01:00.0 wlp1s0: renamed from wlan0
lspci -nnk | grep 0280 -A2 01:00.0 Network controller [0280]: Intel Corporation Wireless 8260 [8086:24f3] (rev 3a) Subsystem: Intel Corporation Wireless 8260 [8086:0050] Kernel driver in use: iwlwifi
Pilot6
  • 92,041
Intel wireless 8260 - unclaimed network should have the answer to this problem, but if it doesn't tell me and I will check.
