I have added Command Applet to the MATE Panel.
I planed to use a command with some scripting inside to check server availability - something like
wget --quiet https://someserver -O - | grep -s somedata > /dev/null && echo "S OK" || echo "S FAIL!"
or
curl -s https://someserver | grep -s somedata > /dev/null && echo "S OK" || echo "S FAIL!"
I have added this command to Preferences.
In terminal it works as expected, but Command Applet shows only # inside:
I tried to move the long command to script file, but got the same result.
