I have the following line in my .profile file in my home directory:
alias flux='redshift -O 2500'
But whenever I login and type flux I get a flux is not a recognized command.
I then do a source .profile and type flux again and it works perfectly.
I am on Ubuntu 20.04
Why is the alias in my .profile not working unless I do a source .profile?
edit: I understand now that .profile is not the correct place to put this.
I ended up loading aliases from the .bashrc file using the source command:
for file in ~/.dotfiles/.{exports,aliases}; do
    [ -r "$file" ] && source "$file"
done
unset file
amortaza
  • 153
TL;DR: As Gunnar Hjalmarsson says, put aliases in ~/.bash_aliases.
The commands in ~/.profile are run by login shells. That file is a good place to do things that should be done once at the beginning of each session but not repeated every time a new shell is started. ~/.profile is good for setting environment variables, which will be inherited by all descendant processes.
Aliases are not inherited, and the shell you get in a terminal window in Ubuntu is not (by default) a login shell. To define aliases for all your interactive Bash shells, the definitions need to be somewhere where they'll be run each time you start such a shell.
The usual places are either in:
  • ~/.bashrc
  • ~/.bash_aliases
New interactive non-login shells source ~/.bashrc (as do some noninteractive shells). Your ~/.profile, by default, sources ~/.bashrc.
The default ~/.bashrc in Ubuntu checks if ~/.bash_aliases exists and sources it.
I recommend putting new aliases in ~/.bash_aliases.
Sourcing ~/.profile works to define the aliases, but it also re-runs everything else in that file, most of which you don't need to run again, and some of which might do things you don't want. For example, ~/.profile checks if ~/bin exists and, if so, prepends it to your $PATH. If you source ~/.profile multiple times, you can get the same directory appearing multiple times in $PATH. This would have to happen quite a lot to cause a significant performance problem. But even one extra occurrence can cause confusion when you're inspecting the output of a command like printenv PATH.
If your aliases aren't defined even in initial login shells, such as when you log in from a virtual console or via SSH, then as Kulfy alludes to the issue may be that you have a ~/.bash_profile or ~/.bash_login file. If such a file exists, Bash login shells source it instead of ~/.profile. Most often you would not want to have either such file on Ubuntu, and if you did, you would most likely want it to source ~/.profile so that the commands in ~/.profile still run.
But even if that is the case, you shouldn't define aliases in ~/.profile (nor in ~/.bash_profile or ~/.bash_login), as that doesn't define them in non-login shells.
Eliah Kagan
  • 119,640
