I have a Dell G3 3579 (Secure Boot Disabled) with Ubuntu 20.04 fully updated. The brightness cannot be changed in either the OS or with the hardware keyboard buttons. Here's what I tried:
  • I reinstalled Nvidia drivers for GTX 1050 Mobile
  • I changed the GRUB_CMDLINE_LINUX_DEFAULT line in /etc/default/grub to:
    "quiet splash nomodeset acpi_backlight=vendor acpi_osi=linux"
  • With this, the transparent backlight appears but the backlight still does not change.
  • I also tried changing acpi_backlight to video
  • I ran ls /sys/class/backlight and there is one entry called dell_backlight
  • I installed backlight-controller but no effect. Errors were output in the terminal when I ran the program from the terminal and moved the sliders
  • Please check and decypher the output of dmesg | grep "ACPI" here
When I had Manjaro installed the brightness could be changed both in the OS and the hardware buttons. Without the brightness working. I will have to keep the laptop plugged in because of the power draw of the screen.
What could be the issue?
LtMuffin
  • 193
  • 13
Changing the GRUB_CMDLINE_LINUX_DEFAULT line in /etc/default/grub from:
to
"quiet splash acpi_backlight=legacy"
works perfectly! It also fixed the 'nvidia-settings' blank window issue.
Check this post for full info 13.04 Upgrade – Brightness not working
LtMuffin
  • 193
  • 13
