Fresh install of Ubuntu 20.04 Server. Setup netplan config. However netplan config stops working after a reboot because the interface names change each time for some reason. Setup netplan config to match on mac address and set name, but this still does not work because interface name changes every reboot.
Tried setting grub back to old interface naming convention (eth0) but did not work. Tried changing netplan config to reflect interface names as (ens0) also did not work.
Interface names that change are random and different each reboot.
dmesg | grep eth output
[ 9.704345] tg3 0000:03:00.0 eth0: Tigon3 [partno(629133-001) rev 5719001] (PCI Express) MAC address ac:16:2d:8c:83:40
[ 9.747819] tg3 0000:03:00.0 eth0: attached PHY is 5719C (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[1])
[ 9.747821] tg3 0000:03:00.0 eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[1] TSOcap[1]
[ 9.747824] tg3 0000:03:00.0 eth0: dma_rwctrl[00000001] dma_mask[64-bit]
[ 9.772054] tg3 0000:03:00.1 eth1: Tigon3 [partno(629133-001) rev 5719001] (PCI Express) MAC address ac:16:2d:8c:83:41
[ 9.887044] tg3 0000:03:00.1 eth1: attached PHY is 5719C (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[1])
[ 9.922968] tg3 0000:03:00.1 eth1: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[1] TSOcap[1]
[ 9.960541] tg3 0000:03:00.1 eth1: dma_rwctrl[00000001] dma_mask[64-bit]
[ 10.027843] tg3 0000:03:00.2 eth2: Tigon3 [partno(629133-001) rev 5719001] (PCI Express) MAC address ac:16:2d:8c:83:42
[ 10.066251] tg3 0000:03:00.2 eth2: attached PHY is 5719C (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[1])
[ 10.105881] tg3 0000:03:00.2 eth2: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[1] TSOcap[1]
[ 10.145704] tg3 0000:03:00.2 eth2: dma_rwctrl[00000001] dma_mask[64-bit]
[ 10.214958] tg3 0000:03:00.3 eth3: Tigon3 [partno(629133-001) rev 5719001] (PCI Express) MAC address ac:16:2d:8c:83:43
[ 10.290362] tg3 0000:03:00.3 eth3: attached PHY is 5719C (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[1])
[ 10.290364] tg3 0000:03:00.3 eth3: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[1] TSOcap[1]
[ 10.290366] tg3 0000:03:00.3 eth3: dma_rwctrl[00000001] dma_mask[64-bit]
[ 10.660995] tg3 0000:03:00.1 eno2: renamed from eth1
[ 11.045599] tg3 0000:03:00.0 eno1: renamed from eth0
[ 12.513784] r8169 0000:09:00.0 eth0: RTL8168c/8111c, 00:e0:4c:69:58:ab, XID 3c4, IRQ 126
[ 12.514210] tg3 0000:03:00.3 eno4: renamed from eth3
[ 12.673906] r8169 0000:09:00.0 eth0: jumbo features [frames: 6128 bytes, tx checksumming: ko]
[ 12.902002] tg3 0000:03:00.2 eno3: renamed from eth2
[ 14.432154] r8169 0000:0a:00.0 eth1: RTL8168c/8111c, 00:e0:4c:69:58:ac, XID 3c4, IRQ 127
[ 14.732638] r8169 0000:0a:00.0 eth1: jumbo features [frames: 6128 bytes, tx checksumming: ko]
[ 14.865814] r8169 0000:0b:00.0 eth2: RTL8168c/8111c, 00:e0:4c:69:58:ad, XID 3c4, IRQ 128
[ 14.865819] r8169 0000:0b:00.0 eth2: jumbo features [frames: 6128 bytes, tx checksumming: ko]
[ 14.877849] r8169 0000:0c:00.0 eth3: RTL8168c/8111c, 00:e0:4c:69:58:ae, XID 3c4, IRQ 129
[ 14.877857] r8169 0000:0c:00.0 eth3: jumbo features [frames: 6128 bytes, tx checksumming: ko]
[ 14.885379] r8169 0000:0b:00.0 ens2: renamed from eth2
[ 19.550328] r8169 0000:0a:00.0 ens7: renamed from eth1
[ 19.585651] r8169 0000:0c:00.0 ens5: renamed from eth3
[ 19.701789] r8169 0000:09:00.0 ens8: renamed from eth0
cat /etc/default/grub
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
# info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=0
GRUB_DISTRIBUTOR=lsb_release -i -s 2> /dev/null || echo Debian
GRUB_CMDLINE_LINUX_DEFAULT="maybe-ubiquity"
GRUB_CMDLINE_LINUX="GRUB_CMDLINE_LINUX="net.ifnames=0 biosdevname=0""
Uncomment to enable BadRAM filtering, modify to suit your needs
This works with Linux (no patch required) and with any kernel that obtains
the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
The resolution used on graphical terminal
note that you can use only modes which your graphic card supports via VBE
you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
Everything I have tried does not resolve.
cat /etc/netplan/*.yaml
#This is the network config written by ''
network:
version: 2
renderer: networkd
ethernets:
eth1:
match:
macaddress: ac:16:2d:8c:83:40
dhcp4: no
optional: true
set-name: eth1
eth2:
match:
macaddress: ac:16:2d:8c:83:41
dhcp4: true
optional: true
set-name: eth2
eth3:
match:
macaddress: ac:16:2d:8c:83:42
dhcp4: true
optional: true
set-name: eth3
eth4:
match:
macaddress: ac:16:2d:8c:83:43
dhcp4: true
optional: true
set-name: eth4
eth5:
match:
macaddress: 00:e0:4c:69:58:ae
dhcp4: no
optional: true
set-name: eth5
eth6:
match:
macaddress: 00:e0:4c:69:58:ad
dhcp4: true
optional: true
set-name: eth6
eth7:
match:
macaddress: 00:e0:4c:69:58:ac
dhcp4: true
optional: true
set-name: eth7
eth8:
match:
macaddress: 00:e0:4c:69:58:ab
dhcp4: true
optional: true
set-name: eth8
bonds:
bond-lan:
interfaces: [eth1, eth5]
addresses: # [my ip address]
gateway4: # my gateway
nameservers:
search: # [my domain]
addresses: # [my name servers]
parameters:
mode: active-backup
/etc/network/interfaces is empty. the file is there, but contains nothing
sudo lshw -C network
*-network:0 DISABLED
description: Ethernet interface
product: NetXtreme BCM5719 Gigabit Ethernet PCIe
vendor: Broadcom Inc. and subsidiaries
physical id: 0
bus info: pci@0000:03:00.0
logical name: eth4
version: 01
serial: ac:16:2d:8c:83:40
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm vpd msi msix pciexpress bus_master cap_list rom ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=tg3 driverversion=3.137 firmware=5719-v1.31 NCSI v1.1.15.0 latency=0 link=no multicast=yes port=twisted pair
resources: irq:57 memory:f67f0000-f67fffff memory:f67e0000-f67effff memory:f67d0000-f67dffff memory:f4000000-f401ffff
*-network:1 DISABLED
physical id: 0.1
bus info: pci@0000:03:00.1
logical name: eth5
version: 01
serial: ac:16:2d:8c:83:41
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
resources: irq:129 memory:f67c0000-f67cffff memory:f67b0000-f67bffff memory:f67a0000-f67affff memory:f4020000-f403ffff
*-network:2 DISABLED
physical id: 0.2
bus info: pci@0000:03:00.2
logical name: eth6
version: 01
serial: ac:16:2d:8c:83:42
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
resources: irq:57 memory:f6790000-f679ffff memory:f6780000-f678ffff memory:f6770000-f677ffff memory:f4040000-f405ffff
*-network:3 DISABLED
physical id: 0.3
bus info: pci@0000:03:00.3
logical name: eth7
version: 01
serial: ac:16:2d:8c:83:43
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
resources: irq:129 memory:f6760000-f676ffff memory:f6750000-f675ffff memory:f6740000-f674ffff memory:f4060000-f407ffff
*-network
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:09:00.0
logical name: eth8
version: 02
serial: 00:e0:4c:69:58:ab
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 duplex=full ip=10.29.250.18 latency=0 link=yes multicast=yes port=MII speed=1Gbit/s
resources: irq:39 ioport:6000(size=256) memory:f7cf0000-f7cf0fff memory:f68f0000-f68fffff
*-network DISABLED
physical id: 0
bus info: pci@0000:0a:00.0
logical name: eth1
version: 02
serial: 00:e0:4c:69:58:ac
width: 64 bits
clock: 33MHz
configuration: broadcast=yes driver=r8169 latency=0 link=no multicast=yes
resources: irq:24 ioport:7000(size=256) memory:f7df0000-f7df0fff memory:f69f0000-f69fffff
*-network DISABLED
physical id: 0
bus info: pci@0000:0b:00.0
logical name: eth2
version: 02
serial: 00:e0:4c:69:58:ad
width: 64 bits
clock: 33MHz
resources: irq:42 ioport:8000(size=256) memory:f7ef0000-f7ef0fff memory:f6af0000-f6afffff
*-network DISABLED
physical id: 0
bus info: pci@0000:0c:00.0
logical name: eth3
version: 02
serial: 00:e0:4c:69:58:ae
width: 64 bits
clock: 33MHz
resources: irq:38 ioport:9000(size=256) memory:f7ff0000-f7ff0fff memory:f6bf0000-f6bfffff
*-network
physical id: 3
logical name: bond-lan
serial: fa:c7:fe:9b:92:cc
capabilities: ethernet physical
configuration: autonegotiation=off broadcast=yes driver=bonding driverversion=3.7.1 firmware=2 ip=10.30.142.69 link=no master=yes multicast=yes
After updating grub file to reflect GRUB_CMDLINE_LINUX="net.ifnames=0" and starting interface names at eth0, names stayed per netplan config file for 3 reboots then the MAC Addresses started moving between interface names preventing network connection from establishing. I decided to reinstall Ubuntu from scratch and, this time, with a live network connection and enabled all interfaces for dhcp. Below are the netplan config file and interfaces.
# This is the network config written by 'subiquity'
network:
ethernets:
eno1:
dhcp4: true
eno2:
dhcp4: true
eno3:
dhcp4: true
eno4:
dhcp4: true
ens2:
dhcp4: true
eth0:
dhcp4: true
eth2:
dhcp4: true
eth3:
dhcp4: true
version: 2
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether ac:16:2d:8c:83:40 brd ff:ff:ff:ff:ff:ff
inet 10.29.250.18/29 brd 10.29.250.23 scope global dynamic eno1
valid_lft 3317sec preferred_lft 3317sec
inet6 fe80::ae16:2dff:fe8c:8340/64 scope link
3: eno2: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether ac:16:2d:8c:83:41 brd ff:ff:ff:ff:ff:ff
4: eno3: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether ac:16:2d:8c:83:42 brd ff:ff:ff:ff:ff:ff
5: eno4: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether ac:16:2d:8c:83:43 brd ff:ff:ff:ff:ff:ff
6: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 00:e0:4c:69:58:ab brd ff:ff:ff:ff:ff:ff
7: ens2: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether 00:e0:4c:69:58:ac brd ff:ff:ff:ff:ff:ff
8: eth2: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether 00:e0:4c:69:58:ad brd ff:ff:ff:ff:ff:ff
9: eth3: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether 00:e0:4c:69:58:ae brd ff:ff:ff:ff:ff:ff
I then proceeded to change my config file to how I wanted it.
network:
ethernets:
eno1:
dhcp4: no
eno2:
dhcp4: true
eno3:
dhcp4: true
eno4:
dhcp4: true
ens2:
dhcp4: true
eth0:
dhcp4: true
eth2:
dhcp4: true
eth3:
dhcp4: no
optional: true
bonds:
bond-lan:
interfaces: [eno1, eth3]
addresses: [ipaddress]
gateway4: gatewayip
nameservers:
search: [domain]
addresses: [name-serversip]
parameters:
mode: active-backup
version: 2
Things were good for 2 reboots and then this
eno1: <NO-CARRIER,BROADCAST,MULTICAST,SLAVE,UP> mtu 1500 qdisc mq master bond-lan state DOWN group default qlen 1000
link/ether 3a:88:89:a5:3f:7e brd ff:ff:ff:ff:ff:ff
3: eth1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
4: eth2: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
5: ens2: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
6: eno2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
inet 10.29.250.21/29 brd 10.29.250.23 scope global dynamic eno2
valid_lft 3463sec preferred_lft 3463sec
inet6 fe80::ae16:2dff:fe8c:8341/64 scope link
7: eth5: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 2e:da:df:ac:3b:3e brd ff:ff:ff:ff:ff:ff
8: eno3: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
9: eno4: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
10: bond-lan: <BROADCAST,MULTICAST,MASTER,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 10.30.142.69/24 brd 10.30.142.255 scope global bond-lan
inet6 fe80::3888:89ff:fea5:3f7e/64 scope link
- eth0 became eth1
- ens2 had MAC 58:ac but now has MAC 58:ad
- eth2 had MAC 58:ad but now has MAC 58:ac
- eth3 had MAC 00:e0:4c:69:58:ae and now has disappeared and I have a new interface eth5 and a completely new MAC of 2e:da:df:ac:3b:3e, but the physical interface is the same.
Another reboot later, and it changes again
2: eno1: <NO-CARRIER,BROADCAST,MULTICAST,SLAVE,UP> mtu 1500 qdisc mq master bond-lan state DOWN group default qlen 1000
3: eno2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
valid_lft 3406sec preferred_lft 3406sec
4: ens2: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
5: eth3: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
6: eth4: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
7: eno3: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
8: eth6: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
The physical interfaces of the motherboard appear to be holding fine and it seems the problem is only occurring on the PCI slot interfaces. At this point I'm at the conclusion there is something wrong with the PCI network card and am looking for a replacement.
