Here is the command:
opam init
Here is the error I am getting:
bash: /use/local/bin/opam: cannot execute binary file: Exec format error
Are there any suggestions on what we should try?
opam init
It seems like you are trying to execute a program that might not be a valid Linux binary; a quick search for this error online will return many sites explaining how to solve it, like these:
Check if the program you're trying to execute is compatible with your Linux kernel version, like these sites I linked suggest.
However, before actually doing this, I'd try changing that path to /usr/local/bin/opam, it also looks like you might have a typo in there (usually in Linux that folder is called usr, not use).
