19
This happens in two different computers, one with Ubuntu 20.04 and another with 18.04.
The left 40% of the tablet maps horizontally to the entire monitor, while vertically it works fine - bottom to top in the tablet is bottom to top in the monitor. The remaining 60% of the tablet is unused. Both computers are dual boot with Windows 10 and the tablet works fine in both.
Is there a way to map the entire tablet area to the entire monitor?
I tried configuring the Wacom tablet using the settings in Ubuntu. I chose tablet absolute and relative, I clicked "map to a single monitor" in the option Map to monitor.
I tried xsetwacom in command line. Following these instructions:
https://ubuntu-mate.community/t/scale-your-wacom-tablet-to-a-single-monitor/8036
I tried setting:
xsetwacom --get "Wacom Co.,Ltd. Intuos S stylus" area
0 0 15200 9500
If I change it to a larger horizontal value:
xsetwacom --set "Wacom Co.,Ltd. Intuos S stylus" area 0 0 30400 9500
The tablet area remains unchanged, but the pen does not go to the horizontal end of the monitor. If I change it to a smaller number (smaller than 15200) then the tablet area where the pen is "active" is reduced.
I also tried:
xsetwacom --set "Wacom Co.,Ltd. Intuos S stylus" MapToMonitor eDP-1
where eDP-1 is my monitor name from typing xrandr.
Thanks for any help!
Update
There is a weird behaviour here. If I switch on my computer with the tablet already plugged in, it works fine! If I plug in the tablet after the computer is on, the problem reported above happens.
If, when it is working fine, I disconnect the tablet and then connect again, the problem above also happens.
Hold the left-most and the right-most buttons until the LED turns off and back on.
https://github.com/linuxwacom/xf86-input-wacom/wiki/Known-Issues#android-misdetect
Signal
  • 546
