I'm working on an Acer Nitro 5 515-43 with a dedicated NVIDIA GTX 1650 and an integrated AMD GPU. I want to use the dedicated GPU all the time. However the system uses the integrated one instead. What can I do to change this? Since the integrated GPU is an AMD one, the optimus/prime solution shouldn't work.
Here is some additional information about the GPUs:
$ lspci -nn | grep -E 'VGA|Display'
05:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Picasso [1002:15d8] (rev c2)
$ glxinfo -B
name of display: :1
display: :1  screen: 0
direct rendering: Yes
Extended renderer info (GLX_MESA_query_renderer):
    Vendor: X.Org (0x1002)
    Device: AMD RAVEN (DRM 3.35.0, 5.4.0-39-generic, LLVM 9.0.1) (0x15d8)
    Version: 20.0.4
    Accelerated: yes
    Video memory: 2048MB
    Unified memory: no
    Preferred profile: core (0x1)
    Max core profile version: 4.6
    Max compat profile version: 4.6
    Max GLES1 profile version: 1.1
    Max GLES[23] profile version: 3.2
Memory info (GL_ATI_meminfo):
    VBO free memory - total: 1756 MB, largest block: 1756 MB
    VBO free aux. memory - total: 3016 MB, largest block: 3016 MB
    Texture free memory - total: 1756 MB, largest block: 1756 MB
    Texture free aux. memory - total: 3016 MB, largest block: 3016 MB
    Renderbuffer free memory - total: 1756 MB, largest block: 1756 MB
    Renderbuffer free aux. memory - total: 3016 MB, largest block: 3016 MB
Memory info (GL_NVX_gpu_memory_info):
    Dedicated video memory: 2048 MB
    Total available memory: 5120 MB
    Currently available dedicated video memory: 1756 MB
OpenGL vendor string: X.Org
OpenGL renderer string: AMD RAVEN (DRM 3.35.0, 5.4.0-39-generic, LLVM 9.0.1)
OpenGL core profile version string: 4.6 (Core Profile) Mesa 20.0.4
OpenGL core profile shading language version string: 4.60
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL version string: 4.6 (Compatibility Profile) Mesa 20.0.4
OpenGL shading language version string: 4.60
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 20.0.4
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
$ lshw -short | grep -i  display
/0/100/1.1/0            display     TU117M [GeForce GTX 1650 Mobile / Max-Q]
/0/100/8.1/0            display     Picasso
The driver of the NVIDIA GPU is:
$ nvidia-detector
nvidia-driver-440
The OS:
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 20.04 LTS
Release:    20.04
Codename:   focal
The kernel:
$ uname -rm
5.4.0-39-generic x86_64
When i run nvidia-xconfig with root privileges and reboot afterwards, I can't get past the initial logo. Only rebooting in recovery mode and deleting /etc/X11/xorg.conf with a subsequent reboot allows me to use the PC again.
Kevin
  • 61
After installing the graphics drivers from Nvidia, there will be an app installed called NVIDIA X server Settings. There is a section called as Prime-Profiles. Under that you can select performance mode (NVIDIA Graphics card only), On-Demand mode (like Windows, for basic task only integrated gpu, heavy task dedicated gpu), or powersaving mode(integrated gpu only).
Alternately you can run sudo prime-select nvidia which will select the dedicated NVIDIA card only.
Note: You will need a reboot to apply the changes.
Abhay Patil
  • 2,793
I recommend installing NVIDIA drivers through the "Additional Drivers" GUI.
Note: NVIDIA driver 390 does not work with kernel versions above 5.15.
If your GPU's latest driver version is 390 you must install 22.04 LTS and install the GA kernel and remove the HWE kernel before attempting to install NVIDIA drivers.
One day, other NVIDIA drivers will probably become unsupported too.
Langdon
  • 81
