I run upgrade after installing all recommended updates from update manager, and I got dialog:
Could not calculate the upgrade
An unresolvable problem occurred while calculating the upgrade:
E:Unable to correct problems, you have held broken packages.
 This can be caused by:
 * Upgrading to a pre-release version of Ubuntu
 * Running the current pre-release version of Ubuntu
 * Unofficial software packages not provided by Ubuntu
If none of this applies, then please report this bug using the command 'ubuntu-bug update-manager' in a terminal.
So I reported bug.
I also tried
umpirsky@umpirsky:~$ sudo apt-get update
Fetched 16.6 kB in 1min 22s (200 B/s)
Reading package lists... Done
W: GPG error: http://archive.canonical.com oneiric Release: The following signatures were invalid: BADSIG 40976EAF437D05B5 Ubuntu Archive Automatic Signing Key <email address hidden>
Any workaround for this?
umpirsky
  • 3,852
I had this problem too on my Lenovo Thinkpad due to ppa graphics dirvers. I solved it by installing ppa-purge and then removing the https://launchpad.net/~oibaf/+archive/graphics-drivers ppa:
sudo apt-get install ppa-purge
sudo ppa-purge ppa:oibaf/graphics-drivers
Alb
  • 276
I had this issue, and found that it was resolved by setting my software-sources back to the ubuntu.com site. (I had a faster mirror selected initially.) Through software Center, I used the Edit menu --> Software Sources ... and on the dialog for Software Sources, I chose 'Main Server'. I then ran sudo apt-get update. After that, it could calculate the changes and upgrade. This primary site was slower, but this solved the problem in my case.
belacqua
  • 23,540
