I have a laptop with Ubuntu 12.04.6 LTS as the OS. I want to install Ubuntu Studio 19.10 Eoan Ermine on this laptop which is the Asus Eee PC with USB 2.0.
DK Bose
  • 44,553
In your case maybe you can't run that Linux for Eee PC, but anyways, To make a bootable flash disk:
Command line version:
you need to plug your flash disk into your laptop and then run sudo mount to see which device is related to it (for example it can be /dev/sdb or something else)
dd if=Your_.iso_of_UbuntuStudio of=/dev/sdX bs=4M conv=fdatasync status=progress
again you need to change the X with the thing you saw in sudo mount output
GUI Version:
there are some apps that helps you to make a bootable flash disk with your distro:
unetbootin https://unetbootin.github.io/
Etcher https://www.balena.io/etcher/
As a note, there are other applications for this purpose, you can always search on google like this name_of_the_application alternativeto then you will find a great site called https://alternativeto.net/ that helps you find alternative software that are free or open source.
SdSaati
  • 201
