Whenever I download .docx and .ppt files from my school, they always look like this.
UTF-8"File%20Name%20Example.docx
It's pretty annoying to have to rename the file every time I download one, so I want to create a bash script that will do the work for me.
I have a School folder, so I'd like to do a bash script that searches the entire directory and subdirectories for any files that start with the "UTF-8"" prefix, then.
  • Have a for loop that removes the prefix from all files starting with that prefix
  • Search the filename for occurences of "%20" and replace it with " "
  • Monitor the School folder so that any time I download another file with the prefix, it will run the script and immediately rename it.
I am pretty new to linux. I have been researching for the last two hours and I am confused on what I should do. Any help would be greatly appreciated. Thanks!
Cyrus
  • 5,789
A basic example of how to monitor files in a folder with systemd.path (in this case /opt/download).
/etc/systemd/system/download-monitor.path:
[Unit]
Description=Download Monitor
[Path] PathExistsGlob=/opt/download/UTF8"*
[Install] WantedBy=multi-user.target
Next, we need to create a .service file with the same basename as the .path file.
/etc/systemd/system/download-monitor.service:
[Unit]
[Service] ExecStart=/opt/bin/filecheck.sh
Last the Exec script file.
/opt/bin/filecheck.sh:
#!/bin/bash
shopt -s nullglob extglob
systemd.path does not pass what changed so we
rename all .docx and .ppt files starting with
UTF8" in the $a folder.
a=/opt/download for b in $a/UTF8"*@(.docx|.ppt); do c="$a/${b#$a/UTF8"}" mv "$b" "$c" && deurlname "$c" done
The deurlname command is found in the renameutils package.
Now we can enable and start our path monitor:
$ systemctl enable download-monitor.path
$ systemctl start  download-monitor.path
You could use incron for this purpose. It is like a cron, but uses events as triggers.
sudo apt install incron
sudo systemctl enable incron
Add your current user to /etc/incron.allow file:
$ sudo cat /etc/incron.allow
[sudo] password for myuser:
myuser
After you've added your user to that file, you could edit incrontab file by that user:
incrontab -e
/home/myuser/test/utfnames      IN_CREATE       /home/myuser/test/renamefiles.sh
As you can see, the first column contains directory path, the second contains watched event (file creation), the third contains command or path to script.
The script contains the next:
for file in /home/myuser/test/utfnames/*
  do mv $file "$(echo $file | sed 's/UTF-8//' | sed 's/%20/ /g')"
done
Do not forget to chmod +x /home/myuser/test/renamefiles.sh
Testing:
myuser@ubuntu:~$ touch 'test/utfnames/UTF-8"Some%20File%20Name.docx'
myuser@ubuntu:~$ touch 'test/utfnames/UTF-8"Some%20File%20Name%202.docx'
myuser@ubuntu:~$ sudo systemctl start incron.service
myuser@ubuntu:~$ ls test/utfnames/
'UTF-8"Some%20File%20Name%202.docx'  'UTF-8"Some%20File%20Name.docx'
myuser@ubuntu:~$ touch 'test/utfnames/UTF-8"Some%20File%20Name%203.docx'
'"Some File Name 2.docx'  '"Some File Name 3.docx'  '"Some File Name.docx'
Gryu
  • 8,002
  • 37
  • 53
