i'm trying to install nordvpn on Ubuntu 20.04, but i get 'NOSPLIT'. I tried multiple solutions here in the stack but it seems I can't get an answer. here what I get after the apt update.
    Get:1 http://repo.nordvpn.com/deb/nordvpn/debian stable InRelease [317 B]
Err:1 http://repo.nordvpn.com/deb/nordvpn/debian stable InRelease
  Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)
Hit:2 http://us.archive.ubuntu.com/ubuntu focal InRelease
Get:3 http://us.archive.ubuntu.com/ubuntu focal-updates InRelease [107 kB]
Get:4 http://us.archive.ubuntu.com/ubuntu focal-security InRelease [107 kB]
Reading package lists... Done
E: Failed to fetch http://repo.nordvpn.com/deb/nordvpn/debian/dists/stable/InRelease  Clearsigned file isn't valid, got 'NOSPLIT' (does the network require authentication?)
E: The repository 'http://repo.nordvpn.com/deb/nordvpn/debian stable InRelease' is not signed.
N: Updating from such a repository can't be done securely and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
after
sudo dpkg -i nordvpn-release_1.0.0_all.deb
seems it didn't add nord repo to sources.list so i add them manually to /sources.list.d/nordvpn.list
deb [arch=amd64] http://repo.nordvpn.com/deb/nordvpn/debian stable main
deb [arch=i386 ] http://repo.nordvpn.com/deb/nordvpn/debian stable main
and I tried to use different network wifi and provider but no light :(. thanks for any help. .
Hamada
  • 145
Jeed
  • 19
I found simple solution, you just need to remove nordvpn-release to get PUBKEY,if you run
remove it by
sudo apt remove nordvpn-release
then add
to your sources.list and run
sudo apt update
you will get NO_PUBKEY error
W:key is not` available: NO_PUBKEY 6B219E535C964CA1
you need key which is last 8 digit from PUBKEY 5C964CA1 then install it by
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv 5C964CA1
and finally run
sudo apt update
sudo apt install nordvpn
Jeed
  • 19
