I have been trying to install cuda 8.0 in ubuntu 20.04. I used the documentation provided in: https://developer.nvidia.com/cuda-80-ga2-download-archive I tried with both the deb(local) and deb(network). However, using sudo apt-get cuda, I get the following error:
cuda : Depends: cuda-11-0 (>= 11.0.1) but it is not going to be installed
From a few other questions I got to know, I could use sudo apt-get cuda-8-0. However that too shows following error:
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: cuda-8-0 : Depends: cuda-runtime-8-0 (>= 8.0.61) but it is not going to be installed Depends: cuda-demo-suite-8-0 (>= 8.0.61) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
Can anyone help what I am doing wrong and how I can install Cuda-8-0 in ubuntu 20.04?
I managed to install CUDA 8.0 on Ubuntu 22 using the runfile and gcc-5, see CUDA 8 and GCC 5 on Ubuntu 22.04
It should be more or less equivalent for Ubuntu 20. (Probably, the kernel patch will need less changes).
