[fresh virtual box vm, using ubuntu 20.04, all updates made during install]
I just try to run make bcmrpi_defconfig on a linux kernel git repository
patched for RT :
wget https://mirrors.edge.kernel.org/pub/linux/kernel/projects/rt/4.19/patch-4.19.127-rt55.patch.gz
zcat patch-4.19.127-rt55.patch.gz | patch -p1
but it say it cannot find the arm compiler...
phil@rt-linux-pi:~/linux$ /home/phil/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/bin/arm-linux-gnueabihf-gcc
bash: /home/phil/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian
/bin/arm-linux-gnueabihf-gcc: No such file or directory
phil@rt-linux-pi:~/linux$ ls /home/phil/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/bin/arm-linux-gnueabihf-gcc -lha
lrwxrwxrwx 1 phil phil 29 Jun 25 22:58 /home/phil/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/bin/arm-linux-gnueabihf-gcc -> arm-linux-gnueabihf-gcc-4.8.3
I now realize arm-linux-gnueabihf-gcc is nowhere to be found on the system
I get this error :
/bin/sh: 1: /home/phil/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/bin/arm-linux-gnueabihf-gcc: not found
./scripts/gcc-version.sh: 26: /home/phil/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/bin/arm-linux-gnueabihf-gcc: not found
./scripts/gcc-version.sh: 27: /home/phil/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/bin/arm-linux-gnueabihf-gcc: not found
./scripts/gcc-version.sh: 29: /home/phil/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/bin/arm-linux-gnueabihf-gcc: not found
init/Kconfig:17: syntax error
init/Kconfig:16: invalid option
./scripts/clang-version.sh: 15: /home/phil/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/bin/arm-linux-gnueabihf-gcc: not found
./scripts/gcc-plugin.sh: 11: /home/phil/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/bin/arm-linux-gnueabihf-gcc: not found
make[1]: *** [scripts/kconfig/Makefile:104: bcmrpi_defconfig] Error 1
make: *** [Makefile:534: bcmrpi_defconfig] Error 2
I tried :
installing build essentials
I installed these packages : libncurses-dev flex bison openssl libssl-dev dkms libelf-dev libudev-dev libpci-dev libiberty-dev autoconf
I moded the PATH variable :
echo $PATH
/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/home/phil/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/bin/
thanks for the time you'll spend on this question
regards
I follow this tutorial : http://www.frank-durr.de/?p=203
