I am very new to Ubuntu. I just set up a Hyper V installation on my Windows laptop, and gave it a 30GB hard drive space.
I got a notification that my root drive is almost full. According to the screenshot below I only have 12GB, almost at maximum capacity. I know the Ubunutu installation itself takes up some space, but 18GB is missing. Any ideas?
I've read some similar posts here, for example, somebody had to post the output of df -h --total . So here it is, in case it helps:
Filesystem Size Used Avail Use% Mounted on
udev 2.9G 0 2.9G 0% /dev
tmpfs 595M 1.4M 594M 1% /run
/dev/sda1 12G 11G 725M 94% /
tmpfs 3.0G 42M 2.9G 2% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 3.0G 0 3.0G 0% /sys/fs/cgroup
/dev/loop1 3.8M 3.8M 0 100% /snap/gnome-system-monitor/100
/dev/loop4 55M 55M 0 100% /snap/core18/1074
/dev/loop3 43M 43M 0 100% /snap/gtk-common-themes/1313
/dev/loop0 150M 150M 0 100% /snap/gnome-3-28-1804/71
/dev/loop2 1.0M 1.0M 0 100% /snap/gnome-logs/61
/dev/loop5 15M 15M 0 100% /snap/gnome-characters/296
/dev/loop6 4.2M 4.2M 0 100% /snap/gnome-calculator/406
/dev/loop7 89M 89M 0 100% /snap/core/7396
/dev/sda15 105M 3.6M 101M 4% /boot/efi
tmpfs 595M 16K 595M 1% /run/user/121
tmpfs 595M 52K 595M 1% /run/user/1000
/dev/loop8 68M 68M 0 100% /snap/sublime-text/85
/dev/loop9 55M 55M 0 100% /snap/core18/1754
/dev/loop10 97M 97M 0 100% /snap/core/9436
/dev/loop11 1.0M 1.0M 0 100% /snap/gnome-logs/100
/dev/loop12 384K 384K 0 100% /snap/gnome-characters/550
/dev/loop13 2.3M 2.3M 0 100% /snap/gnome-system-monitor/148
/dev/loop14 2.5M 2.5M 0 100% /snap/gnome-calculator/748
/dev/loop15 162M 162M 0 100% /snap/gnome-3-28-1804/128
/dev/loop16 63M 63M 0 100% /snap/gtk-common-themes/1506
/dev/loop17 256M 256M 0 100% /snap/gnome-3-34-1804/36
total 24G 12G 12G 52% -
I am not 100% sure what to do with this, it just confirms my problem. The Avail column says that there are 12GB available somewhere. Is this 12GB locked up in the system somewhere?
edit: Output of lsblk:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop0 7:0 0 149.9M 1 loop /snap/gnome-3-28-1804/71
loop1 7:1 0 3.7M 1 loop /snap/gnome-system-monitor/100
loop2 7:2 0 1008K 1 loop /snap/gnome-logs/61
loop3 7:3 0 42.8M 1 loop /snap/gtk-common-themes/1313
loop4 7:4 0 54.4M 1 loop /snap/core18/1074
loop5 7:5 0 14.8M 1 loop /snap/gnome-characters/296
loop6 7:6 0 4M 1 loop /snap/gnome-calculator/406
loop7 7:7 0 88.7M 1 loop /snap/core/7396
loop8 7:8 0 67.6M 1 loop /snap/sublime-text/85
loop9 7:9 0 55M 1 loop /snap/core18/1754
loop10 7:10 0 96.5M 1 loop /snap/core/9436
loop11 7:11 0 956K 1 loop /snap/gnome-logs/100
loop12 7:12 0 276K 1 loop /snap/gnome-characters/550
loop13 7:13 0 2.2M 1 loop /snap/gnome-system-monitor/148
loop14 7:14 0 2.4M 1 loop /snap/gnome-calculator/748
loop15 7:15 0 161.4M 1 loop /snap/gnome-3-28-1804/128
loop16 7:16 0 62.1M 1 loop /snap/gtk-common-themes/1506
loop17 7:17 0 255.6M 1 loop /snap/gnome-3-34-1804/36
sda 8:0 0 30G 0 disk
├─sda1 8:1 0 11.9G 0 part /
├─sda14 8:14 0 4M 0 part
└─sda15 8:15 0 106M 0 part /boot/efi
