I have installed Ubuntu 16.04 on my new Alienware m17 R3 laptop.
- Ethernet model : Killer E3000 PCI-e Gigabit Ethernet Controller
- Wi-Fi model : Killer Wi-Fi 6 AX1650
Currently there is no network devices available.
The following are my outputs from sudo lshw -C network
*-network UNCLAIMED
description: Ethernet controller
product: Realtek Semiconductor Co., Ltd.
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:3d:00.0
version: 03
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list
configuration: latency=0
resources: ioport:3000(size=256) memory:b8300000-b830ffff memory:b8310000-b8313fff memory:b8320000-b838ffff memory:b8390000-b83abfff
*-network UNCLAIMED
description: Network controller
product: Intel Corporation
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:3e:00.0
version: 1a
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix cap_list
resources: memory:b8200000-b8203fff
my current linux kernel is 4.15.0-45-generic
I tried as the answer followed https://askubuntu.com/a/1028199/1098923
sudo apt-get install git
git clone https://git.kernel.org/pub/scm/linux/kernel/git/iwlwifi/backport-iwlwifi.git
cd backport-iwlwifi
make defconfig-iwlwifi-public
sed -i 's/CPTCFG_IWLMVM_VENDOR_CMDS=y/# CPTCFG_IWLMVM_VENDOR_CMDS is not set/' .config
make -j4
sudo make install
but it doesn't work.
sudo apt-get upgrade also doesn't work for me.
This is URL by dmesg | grep iwl | nc termbin.com 9999 -> https://termbin.com/x3ch
[ 4.088665] Loading modules backported from iwlwifi
[ 4.088665] iwlwifi-stack-public:master:8613:3ae69204
[ 4.238893] iwlwifi 0000:3e:00.0: enabling device (0000 -> 0002)
[ 4.245944] iwlwifi 0000:3e:00.0: Direct firmware load for iwl-dbg-cfg.ini failed with error -2
[ 4.245956] iwlwifi 0000:3e:00.0: Direct firmware load for iwlwifi-cc-a0-57.ucode failed with error -2
[ 4.245960] iwlwifi 0000:3e:00.0: Direct firmware load for iwlwifi-cc-a0-56.ucode failed with error -2
[ 4.245964] iwlwifi 0000:3e:00.0: Direct firmware load for iwlwifi-cc-a0-55.ucode failed with error -2
[ 4.245967] iwlwifi 0000:3e:00.0: Direct firmware load for iwlwifi-cc-a0-54.ucode failed with error -2
[ 4.245972] iwlwifi 0000:3e:00.0: Direct firmware load for iwlwifi-cc-a0-53.ucode failed with error -2
[ 4.245975] iwlwifi 0000:3e:00.0: Direct firmware load for iwlwifi-cc-a0-52.ucode failed with error -2
[ 4.245979] iwlwifi 0000:3e:00.0: Direct firmware load for iwlwifi-cc-a0-51.ucode failed with error -2
[ 4.245982] iwlwifi 0000:3e:00.0: Direct firmware load for iwlwifi-cc-a0-50.ucode failed with error -2
[ 4.245986] iwlwifi 0000:3e:00.0: Direct firmware load for iwlwifi-cc-a0-49.ucode failed with error -2
[ 4.245989] iwlwifi 0000:3e:00.0: Direct firmware load for iwlwifi-cc-a0-48.ucode failed with error -2
[ 4.245992] iwlwifi 0000:3e:00.0: Direct firmware load for iwlwifi-cc-a0-47.ucode failed with error -2
[ 4.245996] iwlwifi 0000:3e:00.0: Direct firmware load for iwlwifi-cc-a0-46.ucode failed with error -2
[ 4.246000] iwlwifi 0000:3e:00.0: Direct firmware load for iwlwifi-cc-a0-45.ucode failed with error -2
[ 4.246003] iwlwifi 0000:3e:00.0: Direct firmware load for iwlwifi-cc-a0-44.ucode failed with error -2
[ 4.246007] iwlwifi 0000:3e:00.0: Direct firmware load for iwlwifi-cc-a0-43.ucode failed with error -2
[ 4.246010] iwlwifi 0000:3e:00.0: Direct firmware load for iwlwifi-cc-a0-42.ucode failed with error -2
[ 4.246014] iwlwifi 0000:3e:00.0: Direct firmware load for iwlwifi-cc-a0-41.ucode failed with error -2
[ 4.246017] iwlwifi 0000:3e:00.0: Direct firmware load for iwlwifi-cc-a0-40.ucode failed with error -2
[ 4.246020] iwlwifi 0000:3e:00.0: Direct firmware load for iwlwifi-cc-a0-39.ucode failed with error -2
[ 4.246021] iwlwifi 0000:3e:00.0: no suitable firmware found!
[ 4.246023] iwlwifi 0000:3e:00.0: minimum version required: iwlwifi-cc-a0-39
[ 4.246024] iwlwifi 0000:3e:00.0: maximum version supported: iwlwifi-cc-a0-57
[ 4.246024] iwlwifi 0000:3e:00.0: check git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
Thank you all for reading and your kind assistance in getting my wifi to work!
