Final update
Similar issue has been reported here.
Discourse announcement: Build/CI failures with ros-testing repository enabled?
Update2
Actually, installation of ROS Melodic failed at the end in my case:
 /tmp/apt-dpkg-install-lRVV2P/0767-python-catkin-pkg-modules_0.4.22-1_all.deb
 /tmp/apt-dpkg-install-lRVV2P/0794-python-rospkg-modules_1.2.8-1_all.deb
 /tmp/apt-dpkg-install-lRVV2P/0796-python-rosdistro-modules_0.8.2-1_all.deb
More logs:
Selecting previously unselected package python-catkin-pkg-modules.
Preparing to unpack .../0767-python-catkin-pkg-modules_0.4.22-1_all.deb ...
Unpacking python-catkin-pkg-modules (0.4.22-1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-lRVV2P/0767-python-catkin-pkg-modules_0.4.22-1_all.deb (--unpack):
 trying to overwrite '/usr/lib/python2.7/dist-packages/catkin_pkg/__init__.py', which is also in package python-catkin-pkg 0.3.9-1
Selecting previously unselected package python-rospkg-modules.
Preparing to unpack .../0794-python-rospkg-modules_1.2.8-1_all.deb ...
Unpacking python-rospkg-modules (1.2.8-1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-lRVV2P/0794-python-rospkg-modules_1.2.8-1_all.deb (--unpack):
 trying to overwrite '/usr/lib/python2.7/dist-packages/rospkg/__init__.py', which is also in package python-rospkg 1.1.4-1
Selecting previously unselected package python-rosdistro-modules.
Preparing to unpack .../0796-python-rosdistro-modules_0.8.2-1_all.deb ...
Unpacking python-rosdistro-modules (0.8.2-1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-lRVV2P/0796-python-rosdistro-modules_0.8.2-1_all.deb (--unpack):
 trying to overwrite '/usr/lib/python2.7/dist-packages/rosdistro/__init__.py', which is also in package python-rosdistro 0.6.6-1
Update
When faulty:
 python-rosinstall-generator : Depends: python-catkin-pkg (>= 0.1.28) but it is not going to be installed
                               Depends: python-pkg-resources but it is not going to be installed
                               Depends: python-rosdistro (>= 0.7.3) but it is not going to be installed
                               Depends: python-rospkg but it is not going to be installed
                               Depends: python-yaml but it is not going to be installed
                               Depends: python2 (< 2.8) but it is not installable
                               Depends: python2 (>= 2.7) but it is not installable
                               Depends: python2:any (>= 2.6.6-7~) but it is not installable
apt-cache policy python-rosinstall-generator
python-rosinstall-generator:
  Installed: (none)
  Candidate: 0.1.20-1
  Version table:
     0.1.20-1 500
        500 http://packages.ros.org/ros/ubuntu bionic/main amd64 Packages
        500 http://packages.ros.org/ros/ubuntu bionic/main i386 Packages
     0.1.13-3 500
        500 http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
        500 http://archive.ubuntu.com/ubuntu bionic/universe i386 Packages
apt-cache policy python3-rosinstall-generator
python3-rosinstall-generator:
  Installed: (none)
  Candidate: 0.1.20-1
  Version table:
     0.1.20-1 500
     0.1.13-3 500
I have some issue to install the following package python-rosinstall-generator on Ubuntu 18.04 with apt:
The following packages have unmet dependencies: python-rosinstall-generator : Depends: python2 (< 2.8) but it is not installable Depends: python2 (>= 2.7) but it is not installable Depends: python2:any (>= 2.6.6-7~) but it is not installable E: Unable to correct problems, you have held broken packages.
Since I am using Docker, I have an old image where python-rosinstall-generator has been successfully installed with apt install python-rosinstall-generator:
apt-cache depends python-rosinstall-generator
  Depends: python
  Depends: python
  Depends: <python:any>
    python:i386
    python
  Depends: <python-argparse>
    libpython2.7-stdlib
  Conflicts: python3-rosinstall-generator
After doing apt update in the Docker, it gives now:
  Depends: <python2>
  Depends: <python2>
  Depends: <python2:any>
    libpython2.7-stdlib
And python2 package cannot be installed:
apt install python2
Reading package lists... Done
Building dependency tree
Package python2 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'python2' has no installation candidate
It looks like a recent update has broken something, and has introduced a python2 package dependency.
dockerfile
FROM ubuntu:18.04
ENV DEBIAN_FRONTEND=noninteractive RUN apt-get update && apt-get install --yes
build-essential
software-properties-common
pkg-config
cmake
g++
RUN add-apt-repository "deb http://archive.ubuntu.com/ubuntu $(lsb_release -sc) main universe restricted multiverse"
RUN echo "deb http://packages.ros.org/ros/ubuntu $(lsb_release -sc) main" > /etc/apt/sources.list.d/ros-latest.list RUN apt-key adv --keyserver 'hkp://keyserver.ubuntu.com:80' --recv-key C1CF6E31E6BADE8868B172B4F42ED6FBAB17C654 RUN apt-get update && apt-get install --yes python-rosinstall-generator
Catree
  • 153
It looks like that packages.ros.org repository provides python3-rosinstall-generator package which is not compatible with Ubuntu 18.04 LTS.
The container creation using Dockerfile without such repository is successful:
FROM ubuntu:18.04
build-essential
pkg-config
cmake
g++
But installation of ros-melodic-desktop-full ends successfully using your original Dockerfile.
N0rbert
  • 103,263
One way to go around this issue may be to install it using pip package manager. Since you are using python2 for ROS, just try the following:
sudo apt install python-pip
sudo pip install -U rosdep rosinstall_generator vcstool rosinstall
This has worked for me. I hope this helps.
Aditya
  • 101
