Is there a way to log into the Windows VDI (running on Azure) using an app like "Remote Desktop" on Windows? Currently, I can logging in using the Web page (https://rdweb.wvd.microsoft.com/arm/webclient), but as a result, I would not have access to my microphone and webcam on my computer.
The "official" way is using Web or "Remote Desktop" from Windows. Is there any workaround for this?
Official Microsoft documents: https://docs.microsoft.com/en-us/azure/virtual-desktop/connect-windows-7-and-10
DVT
  • 131
Thank you for the webclient url for VDI! https://rdweb.wvd.microsoft.com/arm/webclient
From what I understand, even if you have the ability to connect through this webclient to the VDI, you might still have issues due to security hardening. In case of a typical rdp situation like with rdesktop tool, you would connect to the server but in some cases it will be the reverse (i.e. Reverse Proxy). Therefore, you would get:
Your sign-in was successful but does not meet the criteria to access this resource. For example, you might be signing in from a browser, app, or location that is restricted by your admin.
More details
Device identifier: Not available
Device platform:
Device state: Unregistered
If you face this issue than my solution would be to install all the fancy windows apps to confirm your device identity (following 2FA etc., AD procedures) in a windows VM inside of your Linux host and then, you would connect to it through the Remote Desktop windows app.
Setup:
Linux host -> Windows VM with Remote Desktop -> VDI / WVI (Windows Virtual Desktop)
