27
I am following this compilation guide for FFmpeg. After compiling all the required dependencies, I get the following error in the last section.
ERROR: gnutls not found using pkg-config
This error occurs when I run the configure command as below :
PATH="$HOME/bin:$PATH" PKG_CONFIG_PATH="$HOME/ffmpeg_build/lib/pkgconfig" ./configure \
  --prefix="$HOME/ffmpeg_build" \
  --pkg-config-flags="--static" \
  --extra-cflags="-I$HOME/ffmpeg_build/include" \
  --extra-ldflags="-L$HOME/ffmpeg_build/lib" \
  --extra-libs="-lpthread -lm" \
  --bindir="$HOME/bin" \
  --enable-gpl \
  --enable-gnutls \
  --enable-libaom \
  --enable-libass \
  --enable-libfdk-aac \
  --enable-libfreetype \
  --enable-libmp3lame \
  --enable-libopus \
  --enable-libvorbis \
  --enable-libvpx \
  --enable-libx264 \
  --enable-libx265 \
  --enable-nonfree
I am compiling FFmpeg on a fresh install of Ubuntu 20.04.
5 Answers5
51
In the ffbuild directory (path : ffmpeg_sources/ffmpeg/ffbuild/), inspecting the config.log gives more info on the error message :
/usr/bin/ld: cannot find -lunistring
collect2: error: ld returned 1 exit status
With help from ffmpeg's IRC channel, installing the libunistring-dev package fixed the problem.
sudo apt-get install libunistring-dev
The other solutions didn't work for me, although I'm on Debian not Ubuntu. For me the solution was:
apt install libgnutls28-dev
Yes, that guide does not work correctly on any Ubuntu build since at least 16.04. The simplest method to solve this problem I've found is to first install the default Ubuntu package and then generate your custom script. Prior to running your ffmpeg compile script, install the default package from official Ubuntu repository of the library that ffmpeg is complaining about:
apt install -y gnutls
The root cause many of these library issues and Package Config appears to be often related to C/C++ syntax that is incorrect in the library source files. This has been an issue (and continues to be one) for several ffmpeg dependencies in Ubuntu, such as VLC's x265 library. The problem is compounded by BitBucket's recent decision to discontinue Mercurial support, including their decision to shutdown its forums, which removed several related discussions and solutions from the Internet. :(
I encountered this problem when building on an HPC (SLURM). The problem turned out to be an old system gcc version (4.8.0). The error disappeared after I loaded gcc 12.2.0 (module load gcc/12.2.0). Note that HPC users don't have sudo access and I've been using Anaconda libgnutls for this purpose.
the -dev libtraries for current ubuntu, the 24.04 2 ! is the solution, thank you so much @heath-raftey ! https://askubuntu.com/a/1399851/1661392
So for Ubuntu 24.04 vanilla oneliner for getting dependencies is:
sudo apt update && sudo apt install cuda-toolkit build-essential masm cmake  gnutls-bin libunistring-dev gnutls-dev libfreetype-dev && \
sudo chown $USER:$USER /usr/local/ -R && \
mkdir -p /usr/local/include/ffnvcodec
ALSO if you are making CUDA, then this is moved out of ffmpeg repo in newer revisions: https://superuser.com/a/1299250
git clone https://git.videolan.org/git/ffmpeg/nv-codec-headers.git && \
cd nv-codec-headers && \
make && \
sudo make install && cd ..
Iff you get lost, search for the exact naming. For example, getting the ffmpeg dependency freetype2 is not straightforward in ubuntu 24.04 2 :
apt search freetype2 | grep dev
returns not the freetype2, as it is named without the 2 in ubuntu packages :D :D :D :
apt search freetype | grep dev
makes it clear that freetype2 is actually in libfreetype-dev
Same error happens on ubuntu 24.04 2. even after installing suggested gnutls-bin (as gnutls is not on
sudo apt search gnutls-bin
) and event after installing the fix in comment,
does not fix the error:
ffmpeg/libpostproc/version.h
If you think configure made a mistake, make sure you are using the latest version from Git. If the latest version fails, report the problem to the ffmpeg-user@ffmpeg.org mailing list or IRC #ffmpeg
