OS: Ubuntu 20.04
My issue:
Dual monitors setup with one 1080p @60hz and another monitor 1440p @144hz. Running on proprietary Nvidia driver 440. Monitor is properly setup at 144hz from display settings and the other one at 60hz. I can clearly see that only the mouse cursor is running at 144hz but other windows ect.. are stuck at 60hz. If I disconnect my 60hz monitor, then the issue is fixed and everything is running at 144hz on my main monitor (cursor + windows).
Here is a xrandr output:
HDMI-0 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 531mm x 299mm
   1920x1080     60.00*+  59.94    50.00    60.05    60.00    50.04
   1680x1050     59.95
   1600x900      60.00
   1280x1024     75.02    60.02
   1280x800      59.81
   1280x720      60.00    59.94    50.00
   1024x768      75.03    60.00
   800x600       75.00    60.32
   720x576       50.00
   720x480       59.94
   640x480       75.00    59.94    59.93
DP-0 connected primary 2560x1440+1920+0 (normal left inverted right x axis y axis) 598mm x 336mm
   2560x1440     59.95 + 144.00*  143.86   119.88    99.90
   1920x1080    143.85   119.93    60.00    59.94    50.00
   1680x1050     59.95
   1600x900      60.00
   1280x800      59.81
   800x600       75.00    60.32
   720x576       50.00
   720x480       59.94
Trying to find a solution on the internet, I understand that this issue has been around for a while with Gnome Desktop. Is there any news / update on it? Any workaround or bug report to Ubuntu team ?
Cheers!
For people having same issue, found a fix from "KermitTheFrogerino" on Reddit:
First add those 2 lines to /etc/environment:
CLUTTER_DEFAULT_FPS=144   #Put your refresh rate
__GL_SYNC_DISPLAY_DEVICE=DP-0 #Mine was DP-0
Then launch Nvidia X Server settings by typing "nvidia-settings" and then disable "Allow Flipping" in the OpenGL menu.
To apply after every reboot, you just need to launch the "nvidia-settings" menu to apply the settings.
Kulfy
  • 18,154
