I installed Ubuntu 20.04 a couple months ago and just recently when I try to wake my computer from suspension and type in the password the screen freezes for at least a minute but the cursor keeps working. It would be really helpful if someone can help me avoid this.
            Asked
            Active
            Viewed 1,789 times
            Delete and clean up your os from garbage and unnecessary files. You should also check that any startup application which can be heavy to load or you have set more applications to startup as the os loads.
I have written a python script to clean os. here is the repo link check it up Cleaner
You can also use gui apps like spacer.
install : sudo apt install stacer
run : stacer
you can check the starup applications using stacer
