Will the files inside my windows 7 get deleted when I install Ubuntu 20.04 version?
Asked
Active
Viewed 97 times
You should always consider the possibility of data loss, especially when you are making changes to partitions or adding/removing operating systems. Always make backups!
If you install Ubuntu instead of Windows 7, everything on Windows 7 will be deleted.
If you install Ubuntu alongside Windows 7, the data should be retained.
FYI: Windows 7 reached End Of Life in January 2020. This OS is no longer safe to use and must be replaced with an operating system that still receives security updates.
Nmath
- 12,664
It depends! If you are replacing Windows 7, Then yes! If you are dual booting, Then no!
jdev082
- 463
