I have an ethernet cable connected to the router and I set up the ubuntu server with the IP 192.168.1.123 using the installation of Ubuntu Server 20.04 Manual IPv4. I used Set static IP on Ubuntu Core and tsteiner answer. This finally worked for installing apt-get commands such as upgrade and update. I am not sure if I set it up right. I really just want to setup a server I can use but access from my desktop computer.
The commands ifconfig, route, and arp all tell to install net-tools which I can't because it can't contact the internet. Sorry
IP Address says enp0s7 inet 192.168.1.123/24 bed 192.168.1.255 scope global enp0s7 valid_lft forever preferred_lft forever inet6 fe80::7285:c2ff:fe5a:9ae5/64 scope link valid_lft forever preferred_lft forever
IP Route default via 192.168.1.254 dev enp0s7 proto static 192.168.1.0/24 dev enp0s7 proto kernel scope link src 192.168.1.123
Also I know I don't have a proxy setup for it and I really don't know how. I know about it being in the /etc/something.
The Subnet that is showing is 255.255.255.0 but then I need it in the CIDR form which it says doesn't exist for 255.255.255.0
Manti
The route, arp and ifconfig commands are a bit old-school - nowadays on Linux there are the iproute2 suite of commands:
Try running:
$ ip address
$ ip route
You definitely want to see an IP address to configured on your network device, but also check that the netmask is correct. In a home network, I would expect the mask to be either /24 or /16 - corresponding to either a class C (ex: 192.168.0.x) or class B (ex: 192.168.x.x) network. If it's /32 (I expect not) then that's definitely wrong!
In the routes, you want to see a default route set to the the router IP in that network - commonly ending in either .1 or maybe .254 but starting with same values as your server IP.
You generally should not need a proxy set up, that's also pretty old-school and/or for super-restrictive networks.
siimphh
  • 26
