I’m trying to install some dependencies and I get errors. For example, with git, I get “package git has no installation candidate’
With libx11-dev and several other prerequisites, I get “unable to locate package”.
muru
  • 207,228
First of all after installation you have to run
sudo apt-get update && sudo dpkg --configure -a
Thi sinitiates your package manager additionaly to keep everything clean
sudo apt-get autoremove && sudo apt-get autoclean
No you are ready to go. start by searching the package you want to install
sudo apt-cache search git
This will bring you the search result and you can do
sudo apt-get install git
If still appears same error then check for content in apt source file probably in /etc/apt/sources.list.d/
However you can always simplify the process by using GUI software called package manager. You can launch that software by searching in menu.
