I'm running Ubuntu 20.04 in dual boot with Windows 10. The way I have my setup configured is there's an SSD with both Windows and Ubuntu operating systems and a second drive with all my data on it, such as downloads and documents, etc. The disk is partitioned under NTFS scheme.
Firstly, I was interested in simply mounting that drive automatically on boot, which I managed by going to disks > selecting the drive > edit mount options > mount at startup. However, a few days afterwards I found myself unable to edit any of the files in the mounted disk. The New Folder and Paste options are greyed out, I can neither save any new file nor edit previous ones. The user permissions showed the files belonging to "root" and so kept me from changing anything. After disabling automount, the file permissions show my username instead of root now but I still can't edit anything.
I have tried numerous solutions, many even successfully, but things revert back to same in a few days for no apparent reason. I would really like to know what's the issue here and how it can be fixed.
Thanks!
I had the exact same setup and faced the same problem. So here is a solution:
  1. Make sure fast startup is turned off in Windows Control Panel\Hardware and Sound\Power Options\System Settings.
  2. Make sure you have shut down your PC and not hibernated it with windows.
VidathD
  • 2,829
What worked for me was login with windows, find the permissions tab and write "everyone" and click full control, click apply, then restart to linux.
