I have acer Predator helios 300 PH315-51. I wish to shift to Ubuntu full time and remove Windows 10. However the only thing holding me back is the Predator Sense software, which is available for Windows 10 only. It basically allows you to control the fan speed and monitor the CPU and GPU temperatures. I have managed to get other 3rd party app to monitor temperatures, however I could not find a software to control the fan speed. Is there any way in which I can install Predator Sense on Ubuntu, or any other software to control the fan speeds.
EDIT 1:
I tried to use wine, but when I run the setup file for predator sense, there is a loading cursor, and then it disappears. And that is it. I tried to run this multiple times.
EDIT 2:
I tried using fancontrol but when I run sudo pwmconfig, I get the following error.
This program will search your sensors for pulse width modulation (pwm)
controls, and test each one to see if it controls a fan on
your motherboard. Note that many motherboards do not have pwm
circuitry installed, even if your sensor chip supports pwm.
We will attempt to briefly stop each fan using the pwm controls.
The program will attempt to restore each fan to full speed
after testing. However, it is ** very important ** that you
physically verify that the fans have been to full speed
after the program has completed.
/usr/sbin/pwmconfig: There are no pwm-capable sensor modules installed
EDIT 3:
Basically I am still looking a way to run Predator Sense on Ubuntu through some sort of compatibility layer or any other fan control method that works, given that lm-sensors does not detect the fan of my laptop.
EDIT 4:
The fan sensor isn't detected. See the output of sensors:
abhay@abhay:~$ sensors
coretemp-isa-0000
Adapter: ISA adapter
Package id 0: +46.0°C (high = +100.0°C, crit = +100.0°C)
Core 0: +45.0°C (high = +100.0°C, crit = +100.0°C)
Core 1: +46.0°C (high = +100.0°C, crit = +100.0°C)
Core 2: +43.0°C (high = +100.0°C, crit = +100.0°C)
Core 3: +43.0°C (high = +100.0°C, crit = +100.0°C)
Core 4: +43.0°C (high = +100.0°C, crit = +100.0°C)
Core 5: +44.0°C (high = +100.0°C, crit = +100.0°C)
pch_cannonlake-virtual-0
Adapter: Virtual device
temp1: +53.0°C
iwlwifi_1-virtual-0
temp1: +44.0°C
BAT1-acpi-0
Adapter: ACPI interface
in0: 16.68 V
curr1: 0.00 A
