I am a linux newbie so this maybe a very stupid question, I will try to ask my question by giving an example. When I execute command in terminal
chromium-browser
chromium opens up but I cannot close the terminal without closing the browser. when I quit the terminal browser closes automatically So I wanted know how to close that terminal without closing the browser.
Shubh
You can do it by running something like this from the terminal:
chromium-browser &
disown
You need to disown the program from the terminal.
More information about disown:
~$ disown --help
disown: disown [-h] [-ar] [jobspec ... | pid ...]
    Remove jobs from current shell.
Removes each JOBSPEC argument from the table of active jobs.  Without
any JOBSPECs, the shell uses its notion of the current job.
Options:
  -a    remove all jobs if JOBSPEC is not supplied
  -h    mark each JOBSPEC so that SIGHUP is not sent to the job if the
        shell receives a SIGHUP
  -r    remove only running jobs
Exit Status:
Returns success unless an invalid option or JOBSPEC is given.
Terrance
  • 43,712
You need to disassociate the browser from the terminal. I think this is the sequence:
chromium-browser </dev/null >/dev/null 2>&1 &
# or
nohup chromium-browser &
disown exit
glenn jackman
  • 18,218
Place an & after any command you want to run in background after the terminal exits.
chromium-browser &
should do the trick.
Reference to StackOverflow question explaining it
Dennis
  • 2,513
