-1
Reading package lists... Done
Building dependency tree
 nvidia-current : Depends: nvidia-304 but it is not going to be installed
I have Ubuntu 18.04.
@adarsh, as suggested, I did to the purge, and followed with a variety of reinstalls (eg, sudo apt-get install nvidia-current), but keep coming back to that same issue. I may not be installing properly. I have 18.04, with "EVGA GeForce RTX 2080 SUPER GAMING 8GB Blower Fan." I am new to linux (ex-windows guy). Can you recommend a specific install sequence to follow the purge? The most recent error is "nvidia-current : Depends: nvidia-304 but it is not going to be installed E: Unable to correct problems, you have held broken packages."
Folks, I could use some help here.
iiyt
It seems like there is something problem with nvidia drivers.
To solve this I would recommend first to remove the drivers using the command
sudo apt-get purge nvidia*
then try to install the drivers from addtional drivers in software and updates. If you still get the error please let me know :)
Adarsh
  • 13
