I downloaded the 64-bit package for the Sogou input method from here https://pinyin.sogou.com/linux/
When I try to install it there are dependency errors on Ubuntu 20.04
Note, selecting 'sogoupinyin' instead of './sogoupinyin_2.3.1.0112_amd64.deb'
sogoupinyin : Depends: fcitx-frontend-qt4 but it is not installable
Depends: libqtwebkit4 but it is not installable
What solution is there to get Sogou input up and running on Ubuntu 20.04?
Thanks
