I've got a Brand New ORICO TCM3-C3 NVMe M.2 SSD enclosure which I am using with a WD Blue WDS500G2B0B-00YS70 500Gb NVMe ssd (also new)
When I plug it in I get the usual ping of a USB device being recognised but when I run lsblk of sudo fdisk -l It does not show up.
dmesg gives the following:
[ 851.445300] usb 2-2: new SuperSpeed Gen 1 USB device number 4 using xhci_hcd
[ 851.466378] usb 2-2: New USB device found, idVendor=152d, idProduct=0583, bcdDevice= 2.09
[ 851.466383] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 851.466386] usb 2-2: Product: External HDD
[ 851.466388] usb 2-2: Manufacturer: External USB3.0
[ 851.466391] usb 2-2: SerialNumber: DD56419883969
[ 851.471581] scsi host0: uas
[ 851.472404] scsi 0:0:0:0: Direct-Access External USB3.0 0209 PQ: 0 ANSI: 6
[ 851.473635] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 859.632889] sd 0:0:0:0: [sda] Unit Not Ready
[ 859.632896] sd 0:0:0:0: [sda] Sense Key : Hardware Error [current]
[ 859.632903] sd 0:0:0:0: [sda] ASC=0x44 <<vendor>>ASCQ=0x81
[ 859.633498] sd 0:0:0:0: [sda] Read Capacity(16) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 859.633504] sd 0:0:0:0: [sda] Sense Key : Hardware Error [current]
[ 859.633510] sd 0:0:0:0: [sda] ASC=0x44 <<vendor>>ASCQ=0x81
[ 859.633938] sd 0:0:0:0: [sda] Read Capacity(10) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 859.633941] sd 0:0:0:0: [sda] Sense Key : Hardware Error [current]
[ 859.633946] sd 0:0:0:0: [sda] ASC=0x44 <<vendor>>ASCQ=0x81
[ 859.634336] sd 0:0:0:0: [sda] 0 512-byte logical blocks: (0 B/0 B)
[ 859.634339] sd 0:0:0:0: [sda] 0-byte physical blocks
[ 859.634699] sd 0:0:0:0: [sda] Test WP failed, assume Write Enabled
[ 859.634821] sd 0:0:0:0: [sda] Asking for cache data failed
[ 859.634828] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 859.635177] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of physical block size (0 byt>
[ 859.654051] sd 0:0:0:0: [sda] Unit Not Ready
[ 859.654060] sd 0:0:0:0: [sda] Sense Key : Hardware Error [current]
[ 859.654069] sd 0:0:0:0: [sda] ASC=0x44 <<vendor>>ASCQ=0x81
[ 859.654498] sd 0:0:0:0: [sda] Read Capacity(16) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 859.654505] sd 0:0:0:0: [sda] Sense Key : Hardware Error [current]
[ 859.654512] sd 0:0:0:0: [sda] ASC=0x44 <<vendor>>ASCQ=0x81
[ 859.654950] sd 0:0:0:0: [sda] Read Capacity(10) failed: Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 859.654956] sd 0:0:0:0: [sda] Sense Key : Hardware Error [current]
[ 859.654965] sd 0:0:0:0: [sda] ASC=0x44 <<vendor>>ASCQ=0x81
[ 859.656373] sd 0:0:0:0: [sda] Attached SCSI disk
I tried this on my laptop running Ubuntu 20.04 kernel 5.4.0-37-generic
and on my raspberry pi4 running the new 64bit pi OS it had basically the same dmesg
Any ideas about if/how I can get this device to work?
