I'm trying to configure a dual boot between Kali Linux and Ubuntu. I have already installed Kali in one partition with about 40G. The rest of the size will be asigned to install Ubuntu. This is how my kali linux partitions looks:
Kali partitions
As you see the kali linux is encrypted with luks and use lvm. I want to do the same with the Ubuntu distro. I have created the partitions for ubuntu like this:
Ubuntu installation partition
the /dev/sda4 is the partition where i need to put ubuntu.
This is the lvm configuration, with a root filesystem and a swap.
Ubuntu lvm
Then when i try to install ubuntu, it show this error The 'grub-efi-amd64-signed' package failed to install into /target/ . Without the GRUB boot loader, the installed system will not boot
I'm using uefi to install the partitions.
What i've done wrong with this setup?
Ok so after trying a lot of things i finally could get rid out this error. I decided to reformat the usb where i was booting to install ubuntu. I made this usb bootable with rufus inside win10, i reformat it inside Debian 9 and then make use of the dd command. Then i boot on it again and the installation continued without problems.
Note This is the guide i followed to create the partitions and to be able to boot
https://vitobotta.com/2018/01/11/ubuntu-full-disk-encryption-manual-partitioning-uefi/
I faced the same problem, I have 512GB SDD and 1TB HDD. I wanted to install Ubuntu 18.04 on HDD while Win10 (UEFI) is installed on SDD. I solved the problem as follows:
  1. Create a bootable USB with Ubuntu 18.04 (choose partition scheme: GPT -this was the issue key point I was using BIOS-EFI while it's important to have only EFI).
  2. Enter the BIOS setting screen and disable secure boot, besides disabling the fast boot. Enable boot from USB hard disk.
  3. I prepared the partitions of the HDD while installing Ubuntu as follow:
    • 500 MB partition for EFI
    • 16000 MB for swap area (some blogs I read suggested to size the swap area minimum as the memory size: in my case= 16GB)
    • I kept the rest of the free size as ex4 for the root directory (you can do partition as you need: / and /home ...)
  4. Start installing and have fun! (in case the Grub boot load hasn't shown while startup you can enter into the boot screen or BIOS setting to add ubuntu as the first boot choice ).
zx485
  • 2,865
Seham
