I am confused about whether my /tmp using tmpfs is respecting the size parameter that I gave to it in /etc/fstab:
My fstab entries now read:
root_pool/var/tmp /tmp /var/tmp zfs rw,nodev,nosuid 0 0
tmpfs /tmp tmpfs rw,nodev,nosuid,noexec,nr_inodes=5k,size=2G,mode=1777 0 0
tmpfs /dev/shm tmpfs defaults,nodev,nosuid,nr_inodes=5k,mode=700,size=4G 0 0
But according to du, it is using half of my memory (which I understand is the default) instead of the size I meant to allocate to it.
~ df /tmp
Filesystem 1K-blocks Used Available Use% Mounted on
tmpfs 65921428 0 65921428 0% /tmp
So is the size parameter simply not having any effect?
I am working with Ubuntu 20.04
Edit I can mount it manually with
sudo mount -oremount,size=4G /tmp
When I do that /tmp is the expected 20.04 GB.
Edit: systemd status:
● tmp.mount - Temporary Directory (/tmp)
Loaded: loaded (/etc/systemd/system/tmp.mount; enabled; vendor preset: enabled)
Active: active (mounted) since Wed 2020-06-17 13:30:35 EDT; 8min ago
Where: /tmp
What: tmpfs
Docs: https://systemd.io/TEMPORARY_DIRECTORIES
man:file-hierarchy(7)
https://www.freedesktop.org/wiki/Software/systemd/APIFileSystems
Tasks: 0 (limit: 154317)
Memory: 76.0K
CGroup: /system.slice/tmp.mount
Jun 17 13:30:35 virtland systemd[1]: Mounting Temporary Directory (/tmp)...
Jun 17 13:30:35 virtland systemd[1]: Mounted Temporary Directory (/tmp).
and journalctl -u tmp.mount
-- Reboot --
Jun 17 13:27:50 virtland systemd[1]: tmp.mount: Directory /tmp to mount over is not empty, mounting an>
Jun 17 13:27:50 virtland systemd[1]: Mounting Temporary Directory (/tmp)...
Jun 17 13:27:50 virtland systemd[1]: Mounted Temporary Directory (/tmp).
Jun 17 13:29:43 virtland systemd[1]: Unmounting Temporary Directory (/tmp)...
Jun 17 13:29:43 virtland systemd[1]: tmp.mount: Succeeded.
Jun 17 13:29:43 virtland systemd[1]: Unmounted Temporary Directory (/tmp).
-- Reboot --
Jun 17 13:30:35 virtland systemd[1]: tmp.mount: Directory /tmp to mount over is not empty, mounting an>
Edit2: Setting the size of tmpfs for /dev/shm is working as expected:
# in fstab
tmpfs 13184288 2328 13181960 1% /run
tmpfs 4194304 41056 4153248 1% /dev/shm
tmpfs 5120 4 5116 1% /run/lock
tmpfs 65921432 0 65921432 0% /sys/fs/cgroup
tmpfs 65921432 0 65921432 0% /tmp
tmpfs 13184284 8 13184276 1% /run/user/1000
Also, it seems that the noexec option, although recommended by many security guides, is problematic because some programs (including apt) need to execute from /tmp. I understand that this can be gotten around, but I don't want to have to figure out every program that needs to be an exception.
