Hope someone can help me with "pi-hole" installation over single board computer:
  • UBUNTU 20.04
  • Rpi4-8GB/64 bit 1.4 firmware version.
I followed the basic links (installation should be very easy):
ed-install and install PI hole and watched (It is same procedure, regardless the version).
My problem is that everything gets "stuck" at this point:
*[✓] Detected ARM-aarch64 architecture
[i] Checking for existing FTL binary...
[i] Latest FTL Binary already installed (v5.0). Confirming Checksum...
[i] Checksum correct. No need to download!
usermod: user 'pihole' does not exist
grep: /etc/pihole/setupVars.conf: No such file or directory
[i] Testing if systemd-resolved is enabled
[i] Systemd-resolved does not need to be restarted
[i] Restarting lighttpd service...ubuntu@ubuntu-server:~$ ^C*
So I never get any status for "completed installation" and not possible to access pi-hole web interface or do anything else including uninstall. It looks like process has been finished but...nothing there.
I tried a lot of suggestions regarding "lighttpd service" but none of mentioned worked:
My typical code when I run the install command from terminal (it seems to work, but nothing installed..or concluded...The system just stops...):
*ubuntu@ubuntu-server:~$ sudo curl -sSL https://install.pi-hole.net | bash
sudo: unable to resolve host ubuntu-server: Name or service not known
[✗] Root user check
Script called with non-root privileges
The Pi-hole requires elevated privileges to install and run
Please check the installer for any concerns regarding this requirement
Make sure to download this script from a trusted source
[✓] Sudo utility check
[✓] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
Existing PHP installation detected : PHP version 7.4.3
[✓] Disk space check
[✓] Update local cache of available packages
[✓] Checking apt-get for upgraded packages... 11 updates available
It is recommended to update your OS after installing the Pi-hole!
Installer Dependency checks...
[✓] Checking for dhcpcd5
[✓] Checking for git
[✓] Checking for iproute2
[✓] Checking for whiptail
SELinux not detected
Using interface: eth0
Using upstream DNS: Quad9 (unfiltered, no DNSSEC) (9.9.9.10, 149.112.112.10)
Static IP already configured
Unable to find IPv6 ULA/GUA address, IPv6 adblocking will not be enabled
[i] IPv4 address: 10.0.10.82/24
[i] IPv6 address:
[i] Web Interface On
[i] Web Server On
[i] Logging On.
[✓] Check for existing repository in /etc/.pihole
[i] Update repo in /etc/.pihole...HEAD is now at 4d25f69 Merge pull request #3321 from pi-hole/release/v5.0
[✓] Update repo in /etc/.pihole
[✓] Check for existing repository in /var/www/html/admin
[i] Update repo in /var/www/html/admin...HEAD is now at b86e4a3 Merge pull request #1247 from pi-hole/release/v5.0
[✓] Update repo in /var/www/html/admin
[i] Main Dependency checks...
[✓] Checking for cron
[✓] Checking for curl
[✓] Checking for dnsutils
[✓] Checking for iputils-ping
[✓] Checking for lsof
[✓] Checking for netcat
[✓] Checking for psmisc
[✓] Checking for sudo
[✓] Checking for unzip
[✓] Checking for wget
[✓] Checking for idn2
[✓] Checking for sqlite3
[✓] Checking for libcap2-bin
[✓] Checking for dns-root-data
[✓] Checking for lighttpd
[✓] Checking for php7.4-common
[✓] Checking for php7.4-cgi
[✓] Checking for php7.4-sqlite3
[✓] Checking for php7.4-xml
[✓] Checking for php-intl
[✓] Enabling lighttpd service to start on reboot...
[i] Creating user 'pihole'...useradd: group pihole exists - if you want to add this user to that group, use -g.
[✗] Creating user 'pihole'
[i] FTL Checks...
ubuntu@ubuntu-server:~$*
ebaruk
  • 311
Problem has been finally SOLVED:
Steps before even starting:
sudo pihole uninstall
sudo apt-get update
sudo apt-get upgrade
sudo apt purge lighttpd sudo pihole -r
useradd -G pihole pihole
sudo apt-get install gamin
Crucial package, required to install .... Which was actually missing in my case is :
This is/was also well covered at: Lighttpd
Before final installation..do a general reboot
(I just did complete power restart)
And after that You are ready to install Pi-hole using command below:
(if You are lucky and no additional "bugs"...)
curl -sSL install.pi-hole.net | sudo bash
ebaruk
  • 311
