10
I installed Ubuntu 20 on my VPS. This is why I'm trying to do:
curl -v https://imenik.tportal.hr/show?action=pretraga&type=bijeleStranice
[1] 438975
root@vps:/var/www/html/tportal# *   Trying 195.29.166.100:443...
* TCP_NODELAY set
* Connected to imenik.tportal.hr (195.29.166.100) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
*   CAfile: /etc/ssl/certs/ca-certificates.crt
  CApath: /etc/ssl/certs
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.3 (OUT), TLS alert, protocol version (582):
* error:1425F102:SSL routines:ssl_choose_client_version:unsupported protocol
* Closing connection 0
curl: (35) error:1425F102:SSL routines:ssl_choose_client_version:unsupported protocol
But when I try like this, it kinda works
curl -v http://imenik.tportal.hr/show?action=pretraga&type=bijeleStranice
[1] 438977
root@vps:/var/www/html/tportal# *   Trying 195.29.166.100:80...
* TCP_NODELAY set
* Connected to imenik.tportal.hr (195.29.166.100) port 80 (#0)
> GET /show?action=pretraga HTTP/1.1
> Host: imenik.tportal.hr
> User-Agent: curl/7.68.0
> Accept: */*
* Mark bundle as not supporting multiuse
< HTTP/1.1 301 Moved Permanently
< Date: Tue, 16 Jun 2020 07:44:32 GMT
< Server: Apache/2.2.3 (CentOS)
< Location: https://imenik.tportal.hr/show?action=pretraga
< Content-Length: 336
< Connection: close
< Content-Type: text/html; charset=iso-8859-1
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>301 Moved Permanently</title>
</head><body>
<h1>Moved Permanently</h1>
<p>The document has moved <a href="https://imenik.tportal.hr/show?action=pretraga">here</a>.</p>
<hr>
<address>Apache/2.2.3 (CentOS) Server at imenik.tportal.hr Port 80</address>
</body></html>
I can't find a solution to this SSL problem
The Website uses the old TLS protocol version 1.0, which has been disabled by default since Ubuntu 20.04.
To temporarily override the default for your curl command, you can create a config file somewhere (e.g. ~/.openssl_allow_tls1.0.cnf with following content:
openssl_conf = openssl_init
[openssl_init] ssl_conf = ssl_sect
[ssl_sect] system_default = system_default_sect
[system_default_sect] CipherString = DEFAULT@SECLEVEL=1
Then run your command like this:
OPENSSL_CONF=~/.openssl_allow_tls1.0.cnf curl -v https://imenik.tportal.hr/show?action=pretraga&type=bijeleStranice
(this will only set OPENSSL_CONF for that single command)
or
export OPENSSL_CONF=~/.openssl_allow_tls1.0.cnf
(this will only set OPENSSL_CONF for the current session or script)
You could also set it globally in /etc/ssl/openssl.cnf, but it has been disabled for good reasons and I would only override that when necessary.
(via)
pLumo
  • 27,991
Edit the openssl.conf file:
sudo nano /etc/ssl/openssl.cnf
Add this line at the top:
And add these lines at the end:
[openssl_init]
ssl_conf = ssl_sect
It works for me. :)
For the Laravel, also run
sudo service php7.4-fpm restart
WHY
  • 351
