I was having problem with booting Ubuntu. Then I used Easeus partition manager to delete the partition that has Ubuntu. Maybe I have done it wrong. Because now I have also lost Windows. Luckily I came to know of a tool called boot repair from this forum. I used and here is the result from it Paste bin boot info summary. Can someone please decipher what this says and possibly help me out. Thanks.
Solution with Win PE
If you have a Win PE system , install it onto your usb key or burn a CD.
Downlaod http://www.sysint.no/nedlasting/mbrfix.htm and try the command.
I've done this multiple times , it's easy to fix.
Solution with grub-0.9*
Use grub to load your windows , e.g
grub> rootnoverify (hdA,B)
grub> makeactive
grub> chainloader +1
grub> boot
It may fail , but worth a try. (At least for Windows XP I tried last time)
- 6,712
You need either Windows disk or (Ubuntu) Linux live CD/USB. Do everything possible to boot into a live desktop/system.
For Windows, in command prompt run fixmbr.
For Ubuntu or other Linux live-system,
Method 1: Install syslinux.
sudo apt-get install syslinux
Then, use following commands write mbr (Use sudo fdisk -l to find out your device name):
sudo dd if=/usr/lib/syslinux/mbr.bin of=/dev/sda
Method 2: Install mbr
sudo apt-get install mbr
Then, write mbr by:
sudo install-mbr -i n -p D -t 0 /dev/sda
Since you said you don't have a windows disc, try reinstalling grub from a ubuntu live cd:
https://help.ubuntu.com/community/RecoveringUbuntuAfterInstallingWindows
- 1,974
