After resuming from hibernation, my mouse will work fine for about 0.5~1 minute, then stop working for about 1~3 seconds, and then it will work again.
During the 3 seconds, I can see that on the top right corner, the Bluetooth icon disappear then appear.
Here is the log for bluetooth.service
$ journalctl -u bluetooth.service
It is fine until Endpoint registered. You can see the bluetooth.service is stopped & started. That is because I've added a script to do that after hibernation because I thought it can solve the problem. Without doing that, the symptom is the same.
un 15 18:26:01 ubt bluetoothd[35322]: Endpoint unregistered: sender=:1.38 path=/MediaEndpoint/A2DPSink/sbc
Jun 15 18:26:01 ubt bluetoothd[35322]: Endpoint unregistered: sender=:1.38 path=/MediaEndpoint/A2DPSource/sbc
Jun 15 18:26:02 ubt bluetoothd[35322]: Terminating
Jun 15 18:26:02 ubt systemd[1]: Stopping Bluetooth service...
Jun 15 18:26:02 ubt bluetoothd[35322]: Stopping SDP server
Jun 15 18:26:02 ubt bluetoothd[35322]: Exit
Jun 15 18:26:02 ubt systemd[1]: bluetooth.service: Succeeded.
Jun 15 18:26:02 ubt systemd[1]: Stopped Bluetooth service.
Jun 15 18:26:02 ubt systemd[1]: Starting Bluetooth service...
Jun 15 18:26:02 ubt bluetoothd[36505]: Bluetooth daemon 5.53
Jun 15 18:26:02 ubt systemd[1]: Started Bluetooth service.
Jun 15 18:26:02 ubt bluetoothd[36505]: Starting SDP server
Jun 15 18:26:02 ubt bluetoothd[36505]: Bluetooth management interface 1.14 initialized
Jun 15 18:26:03 ubt bluetoothd[36505]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSink/sbc
Jun 15 18:26:03 ubt bluetoothd[36505]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource/sbc
Jun 15 18:26:24 ubt bluetoothd[36505]: bt_uhid_send: Invalid argument (22)
Jun 15 18:26:56 ubt bluetoothd[36505]: bt_uhid_send: Invalid argument (22)
