I don't think my needs are all that unique. I have a home network wired and wireless with multiple devices running Ubuntu 16.04.6 LTS. They will be upgraded to 20.04 soon though. My desire is to setup each device both as a Client AND Server to every other device. Currently I have:
  • Dell Inspiron 17R SE 7720 laptop
  • Dell Alienware 17R3 laptop
  • Same user name on both machines
I'm looking for a script that will install and configure ssh or openssh-client AND openssh-server on both machines. This assumes ssh includes both client and server.
The script will:
  1. Remove ssh if already installed. (This may not be necessary I guess...)
  2. Install ssh and trigger sshd to run by systemd.
  3. Name the machine in /etc/hosts or /etc/resolve or where ever network names are needed.
  4. Setup the static IP's wherever static IP's are setup.
  5. Create the keys whereever keys are setup.
  6. Block out access to any device not on LAN.
  7. Automatically prevent snooping or spoofing or whatever sping there is to prevent.
  8. Set current machine up as valid client to all other machines (who are also servers) on the LAN. Probably involves copying SSH client keys.
  9. Ask Ubuntu Q&A: Automatically change Terminal colors on remote connection?
Do everything else required per internet articles:
Calling the script should be straight forward with:
sudo ssh-setup HOST_NAME USER_NAME
Again the machine is setup as both a server and a client. Initially I'll just have two laptops. Later on I'll want to add my Linux Kernel based phones and TV's running Android. Initially all machines will just have the single user ID.
Is there a script already out there or do I have to write my own?
June 13, 2020 update
I've begun writing a script but it will take at least a week to complete.
Introduction
My final script (ssh-setup) is done and SSH Open Server has been installed. The script doesn't do as much as originally envisioned. Someone can take it and modify it for automated setup in a large organization though. For everyone else it hopefully provides useful details to aid in installation.
Before raising concerns about MAC addresses below note that:
Says:
MAC addresses are almost always only used "internally" (between you and your immediate gateway). They really don't make it to the outside world and thus cannot be used to connect back to you, locate you, or otherwise cause you any direct harm.
ssh-setup Sample Output
$ sudo ssh-setup
Gathering system details - Will take 15 - 30 seconds
========== systemctl status net* ============================================
  • network-online.target - Network is Online (... OUTPUT SNIPPED TO SAVE SPACE ...)
  • networking.service - Raise network interfaces (... OUTPUT SNIPPED TO SAVE SPACE ...)
  • network.target - Network (... OUTPUT SNIPPED TO SAVE SPACE ...)
  • network-pre.target - Network (Pre) (... OUTPUT SNIPPED TO SAVE SPACE ...)
========== systemctl status ssh =============================================
  • ssh.service Loaded: not-found (Reason: No such file or directory) Active: inactive (dead)
========== [[ -d ~/.ssh ]] && SSH_Keys=$(ls -al ~/.ssh) =====================
-rw------- 1 rick rick 1679 Oct 8 2019 id_rsa -rw-r--r-- 1 rick rick 392 Oct 8 2019 id_rsa.pub -rw-r--r-- 1 rick rick 1108 Jun 17 20:53 known_hosts
========== apt list 2>/dev/null | grep ssh | grep installed =================
libssh-4/xenial-updates,xenial-security,now 0.6.3-4.3ubuntu0.5 amd64 libssh-gcrypt-4/xenial-updates,xenial-security,now 0.6.3-4.3ubuntu0.5 amd64 libssh2-1/xenial-updates,xenial-security,now 1.5.0-2ubuntu0.1 amd64 openssh-client/xenial-updates,xenial-security,now 1:7.2p2-4ubuntu2.8 amd64 sshfs/xenial,now 2.5-1ubuntu1 amd64
========== cat /etc/ssh/sshd.config =========================================
========== ifconfig -a | grep -v ^' ' -A1 ===================================
enp59s0 Link encap:Ethernet HWaddr 28:f1:0e:2a:1a:ed
inet addr:192.168.0.12 Bcast:192.168.0.255 Mask:255.255.255.0
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
wlp60s0 Link encap:Ethernet HWaddr 9c:b6:d0:10:37:f7
inet addr:192.168.0.10 Bcast:192.168.0.255 Mask:255.255.255.0
========== nmap -sn 192.168.0/24 ============================================
hitronhub.home (192.168.0.1) (0.0011s latency). MAC: AC:20:2E:CC:94:52 (Unknown) dell (192.168.0.13) (0.00026s latency). MAC: 5C:F9:DD:5C:9C:53 (Dell) dell (192.168.0.14) (0.00026s latency). MAC: 5C:F9:DD:5C:9C:53 (Dell) hs100 (192.168.0.15) (-0.078s latency). MAC: 50:D4:F7:EB:41:35 (Unknown) android-47cdabb50f83a5ee (192.168.0.16) (-0.076s latency). MAC: 18:4F:32:8D:AA:97 (Hon Hai Precision Ind.) 192.168.0.254 (0.00045s latency). MAC: 00:05:CA:00:00:09 (Hitron Technology) alien (192.168.0.10) LOCAL NETWORK CARD alien (192.168.0.12) LOCAL NETWORK CARD
========== lshw -c network | grep -Ei 'description|product|serial' ==========
Ethernet interface: Killer E2400 Gigabit Ethernet Controller - 28:f1:0e:2a:1a:ed Wireless interface: QCA6174 802.11ac Wireless Network Adapter - 9c:b6:d0:10:37:f7
========== cat /etc/hosts | grep 192.168 ====================================
192.168.0.10 alien AW 17R3 WiFi 9c:b6:d0:10:37:f7 192.168.0.12 alien AW 17R3 Ethernet 28:f1:0e:2a:1a:ed 192.168.0.13 dell Inspiron 17R-SE-7720 Ethernet 5c:f9:dd:5c:9c:53 192.168.0.14 dell Inspiron 17R-SE-7720 WiFi 60:6c:66:86:de:bd 192.168.0.15 hs100 Sony TV Wall Light 192.168.0.16 android-47cdabb50f83a5ee Sony Bravia TV KBL 50W800C
========== FIREWALL: ufw status verbose =====================================
Status: active Logging: on (low) Default: deny (incoming), allow (outgoing), disabled (routed) New profiles: skip -------------- Any error messages below are coming from tlp-stat -------------- cat: /sys/class/power_supply/hidpp_battery_35/present: No such file or directory cat: /sys/class/power_supply/hidpp_battery_36/present: No such file or directory
========== tlp-stat | grep -E '^autosuspend|ENABLE|WOL' =====================
TLP_ENABLE=1 WOL_DISABLE=Y autosuspend = enabled
========== cat /etc/default/halt ============================================
Default behaviour of shutdown -h / halt. Set to "halt" or "poweroff".
HALT=poweroff
========== cat /etc/network/interfaces ======================================
interfaces(5) file used by ifup(8) and ifdown(8)
For Ubuntu 16.04 ONLY according to notes in ssh-setup
auto lo iface lo inet loopback
auto eth0 iface eth0 inet static address 192.168.0.10 netmask 255.255.255.0 gateway 192.168.0.1 dns-nameservers 192.168.0.1 up ethtool -s eth0 wol g
========== nmcli -p connection show =========================================
==================================================================================== NetworkManager connection profiles ==================================================================================== NAME UUID TYPE DEVICE
XXXX-XXXXXX-5G cf8fda92-0e59-4d0e-8821-cedb4be10d26 802-11-wireless wlp60s0 Wired connection 1 378122bb-ad44-3ddd-a616-c93e1bf0f828 802-3-ethernet enp59s0 XXXXXXXXX-5G 73c40a50-0f2e-431c-b12c-e4712b3abdb4 802-11-wireless --
========== ifconfig -a | grep ^'e' | cut -d' ' -f1 ==========================
Ethernet Interface that could be used for WOL: enp59s0
========== ethtool enp59s0 | grep -i 'Wake-on:' =============================
========== END OF REPORT ====================================================
Although the report is long already it could be made even longer with explanations for each section. The explanations including links are in the actual script itself.
ssh-setup Bash Script
The script must be called with sudo powers. The same script is designed to be run on both the server and client. Some files such as /etc/hosts you will need to setup after running the report and then copy (perhaps by email) between machines.
After creating the script in a directory, remember to mark it executable with:
chmod a+x /path/to/ssh-setup
Then call the script with sudo /path/to/ssh-setup or simply ssh-setup if the /path/to/ is in your PATH environment variable. Where: /path/to/ is the folder you created the script in.
#!/bin/bash
PATH: /mnt/e/bin
DESC: Display network details needed to setup SSH or debug after setup.
CALL: Called from terminal with sudo permissions.
DATE: June 18, 2020. Modified: Original Version.
NOTE: When debugging script place terminal results in appropriate sections.
From: https://askubuntu.com/questions/628383/output-only-mac-address-on-ubuntu#comment892989_628387
export LANG=C # Force english names for sed search. For example in # another language HWaddr is direcciónHW
if [[ $(id -u) != 0 ]]; then # root powers needed to call this script echo >&2 "'$(basename $0)' must be called with 'sudo'" exit 1 fi
Must have the nmap package.
command -v nmap >/dev/null 2>&1 || { echo >&2
"'nmap' package required but it is not installed. Aborting.";
exit 2; }
Must have the lshw package.
command -v lshw >/dev/null 2>&1 || { echo >&2
"'lshw' package required but it is not installed. Aborting.";
exit 3; }
OTHER PACKAGES CONSIDERED AND REJECTED:
$ network-test
The program 'network-test' is currently not installed. You can install it
by typing: 'sudo apt install ifupdown-extra'
Seems kind of lame and has md5 checksum error.
$ netstat | wc -l
824
Way to many lines to make use of. Might be good to track down specific addy.
$ iwconfig
wlp60s0 IEEE 802.11 ESSID:"XXXXXXXXXXXXXX"
Mode:Managed Frequency:5.22 GHz Access Point: AE:20:2E:CC:94:50
Bit Rate=6 Mb/s Tx-Power=23 dBm
Reveals router name (EESID) which is bad for neighbours to know us by....
echo echo "Gathering system details - Will take 15 - 30 seconds"
Display () {
$1 = command that was run (sometimes abridged version if lots of seds)
$2 = output from command
echo " " String1="========== $1 " String2="=====================================================================" String3="$String1$String2" echo "${String3:0:79}" echo " " echo "$2"
} # Display
What systemd network services are running?
NET_Service="" # Default no directory NET_Service=$(systemctl status net) Display 'systemctl status net' "$NET_Service"
: <<'END' /* ------------ RESULTS -------------------------------------------------------
(ABRIDGED)
---------------------------------------------------------------------------- */ END
Is SSH systemd service (aliased as sshd) running?
SSH_Service="" # Default no directory SSH_Service=$(systemctl status ssh) Display 'systemctl status ssh' "$SSH_Service"
● ssh.service Loaded: not-found (Reason: No such file or directory) Active: inactive (dead)
What SSH keys are already setup?
SSH_Keys="" # Default no directory [[ -d ~/.ssh ]] && SSH_Keys=$(ls -al ~/.ssh |
grep -v ^total |
grep -v ^d ) # remove total line, ./ and ../ directories Display '[[ -d ~/.ssh ]] && SSH_Keys=$(ls -al ~/.ssh)' "$SSH_Keys"
id_rsa id_rsa.pub known_hosts
What SSH packages are currently installed?
SSH_Installed="" # Default no SSH packages SSH_Installed=$(apt list 2>/dev/null | grep ssh | grep installed |
sed 's/ [installed.*//') # remove [installed] & [installed, automatic] strings
Display "apt list 2>/dev/null | grep ssh | grep installed" "$SSH_Installed" : <<'END' /* ------------ RESULTS -------------------------------------------------------
What is the SSH configuration?
SSH_Config="" # Default no SSH packages [[ -f ~/etc/ssh/sshd.config ]] && SSH_Config=$(cat ~/etc/ssh/sshd.config) Display "cat /etc/ssh/sshd.config" "$SSH_Config" : <<'END' /* ------------ RESULTS ------------------------------------------------------- ---------------------------------------------------------------------------- */ END
What IP address are on this machine?
LOCAL_IP_Addresses="" # Default machine has no network cards LOCAL_IP_Addresses=$(ifconfig -a | grep -v ^' ' -A1 |
grep -v '--') # grep to -v to remove extra lines Display "ifconfig -a | grep -v ^' ' -A1" "$LOCAL_IP_Addresses" : <<'END' /* ------------ RESULTS -------------------------------------------------------
What IP address (potential servers/clients) are visible on network?
NET_IP_Addresses="" # Default LAN is not running NET_IP_Addresses=$(nmap -sn 192.168.0/24 |
sed '/^Starting Nmap/d' |
sed '/^Nmap done/d' |
sed -z 's/Nmap scan report for //g' |
sed -z 's/\nHost is up./ LOCAL NETWORK CARD/g' |
sed -z 's/\nHost is up / /g' |
sed -z 's/\nMAC Address: / MAC: /g' )
sed 's/MAC.*(/(/g') # MAC makes line too long
               # Use sed to remove line breaks making results lengthy
Display "nmap -sn 192.168.0/24" "$NET_IP_Addresses" : <<'END' /* ------------ RESULTS -------------------------------------------------------
hitronhub.home (192.168.0.1) (0.00072s latency). (Unknown) dell (192.168.0.13) (0.00021s latency). (Dell) dell (192.168.0.14) (0.00022s latency). (Dell) hs100 (192.168.0.15) (0.010s latency). (Unknown) android-47cdabb50f83a5ee (192.168.0.16) (0.0093s latency). (Hon Hai Precision Ind.) 192.168.0.254 (-0.100s latency). (Hitron Technology) alien (192.168.0.10) LOCAL NETWORK CARD alien (192.168.0.12) LOCAL NETWORK CARD
#What network cards are installed: NetworkCards="" # Contents of /etc/hosts should contain all IP addresses on LAN NetworkCards=$(lshw -c network | grep -Ei 'description|product|serial' |
sed 's/ description: //g' |
sed -z 's/\n product: /: /g' |
sed -z 's/\n serial: / - /g') Display "lshw -c network | grep -Ei 'description|product|serial'" "$NetworkCards" : <<'END' /* ------------ RESULTS -------------------------------------------------------
Email /etc/hosts file to yourself and update contents below on machine
STATIC_IP_Addresses="" # Contents of /etc/hosts should contain all IP addresses on LAN STATIC_IP_Addresses=$(cat /etc/hosts | grep 192.168) Display "cat /etc/hosts | grep 192.168" "$STATIC_IP_Addresses" : <<'END' /* ------------ RESULTS -------------------------------------------------------
Firewall
Selecteend TLP stats that might prove helpful for debuggin.
ufw_stats="" # Contents of /etc/hosts should contain all IP addresses on LAN ufw_stats=$(ufw status verbose) Display "FIREWALL: ufw status verbose" "$ufw_stats" : <<'END' /* ------------ RESULTS -------------------------------------------------------
Status: active Logging: on (low) Default: deny (incoming), allow (outgoing), disabled (routed) New profiles: skip -------------- Any error messages below are coming from tlp-stat -------------- cat: /sys/class/power_supply/hidpp_battery_23/present: No such file or directory cat: /sys/class/power_supply/hidpp_battery_24/present: No such file or directory
echo --------------
Selected TLP stats that might prove helpful for debuggin.
TLP_stats="" # Contents of /etc/hosts should contain all IP addresses on LAN command -v tlp-stat >/dev/null 2>&1 &&
TLP_stats=$(tlp-stat | grep -E '^autosuspend|ENABLE|WOL') Display "tlp-stat | grep -E '^autosuspend|ENABLE|WOL'" "$TLP_stats" : <<'END'
: <<'END' /* ------------------ WOL (Wake On LAN) General Comments --------------------
******************* UBUNTU 16.04 *******************
From: https://askubuntu.com/questions/764158/ how-to-enable-wake-on-lan-wol-in-ubuntu-16-04
Also: http://manpages.ubuntu.com/manpages/xenial/man8/NetworkManager.8.html
In Ubuntu 16.04 set WOL_DISABLE=N in /etc/default/tlp to avoid getting WOL disabled by TLP power management.
http://linrunner.de/en/tlp/docs/tlp-configuration.html
Add NETDOWN=no in /etc/default/halt to prevent powering off the network card during shutdown
Enable Wake on LAN in /etc/network/interfaces when static network configuration is used.
This file describes the network interfaces available on your system
and how to activate them. For more information, see interfaces(5).
The loopback network interface
The primary network interface
Enable wake on lan in BIOS, enter the BIOS setup and look for something called "Wake up on PCI event", "Wake up on LAN" or similar. Change it so that it is enabled. Save your settings and reboot.
https://help.ubuntu.com/community/WakeOnLan
Warning some motherboards / network controllers don't support WOL from the cold boot (S5 state, where the power to the system is physically turned off and back on again). In that case, at least one power cycle (power up, shutdown) has to be performed. To mitigate to the problem, the BIOS can be configured to power up when AC is restored and schedule a shutdown inside Ubuntu afterwards. Refer to the motherboard's manual for further details.
******************* UBUNTU 18.04 *******************
NOTE: In Ubuntu 18.04 /etc/network/interfaces maybe DEPRECATED You might have to create your own script for WOL in: /etc/NetworkManager/dispatcher.d/99-Xxxxxx
  See: https://askubuntu.com/a/1111656/307523
       https://wiki.archlinux.org/index.php/
       NetworkManager#Network_services_with_NetworkManager_dispatcher
WOL from: https://wiki.debian.org/WakeOnLan
apt install ethtool
Above is NOT PERSISTENT across suspend/resume cycle so issue upon resume
not just boot. /etc/network/interfaces above has setup.
Archwiki: https://wiki.archlinux.org/index.php/Wake-on-LAN
apt install wakeonlan
wol target_MAC_address
wol-wakeonlan-guide-remotely-turn-on-servers-without-physical-access/
wakeonlan 5c:f9:dd:5c:9c:53
Do we have 'NETDOWN=no' line present for machines that shutdown"?
HaltConfig="" # Default no file [[ -f /etc/default/halt ]] && HaltConfig=$(cat /etc/default/halt) Display 'cat /etc/default/halt' "$HaltConfig" : <<'END' /* ------------ RESULTS -------------------------------------------------------
HALT=poweroff
Do we have static IP addresses setup?
NetworkInterfaces="" # Default no file [[ -f /etc/network/interfaces ]] && NetworkInterfaces=$(cat /etc/network/interfaces) Display 'cat /etc/network/interfaces' "$NetworkInterfaces" : <<'END' /* ------------ RESULTS -------------------------------------------------------
Hide your router address below if publishing!
nmcliConnections="" # Default no file nmcliConnections=$(nmcli -p connection show) Display 'nmcli -p connection show' "$nmcliConnections" : <<'END' /* ------------ RESULTS -------------------------------------------------------
Xxxx-Xxxxxx-Xx cf8fda92-0e59-4d0e-8821-cedb4be10d26 802-11-wireless wlp60s0 Wired connection 1 378122bb-ad44-3ddd-a616-c93e1bf0f828 802-3-ethernet enp59s0 Xxxxxxxxx-5G 73c40a50-0f2e-431c-b12c-e4712b3abdb4 802-11-wireless --
EthernetInterface=$(ifconfig -a | grep ^'e' | cut -d' ' -f1) Display "ifconfig -a | grep ^'e' | cut -d' ' -f1"
"Ethernet Interface that could be used for WOL: $EthernetInterface" : <<'END' /* ------------ RESULTS -------------------------------------------------------
What WOL_Settings exist for Ethernet Interface?
WOL_Setting="'ethtool' not installed." command -v ethtool >/dev/null 2>&1 &&
WOL_Setting="$(ethtool $EthernetInterface | grep -i 'Wake-on:')" Display "ethtool $EthernetInterface | grep -i 'Wake-on:'" "$WOL_Setting" : <<'END'
Supports Wake-on: pumbag Wake-on: g
Display 'END OF REPORT' ""
TEST STUFF
#Spare: : <<'END' /* ------------ RESULTS ------------------------------------------------------- ---------------------------------------------------------------------------- */ END
