When I want to kill a process via System Monitor I am presented with 2 quick ways, Kill Process and End Process. What is the difference between these two?
I was curious too, so I just browsed through the source code and found the below in application.cpp. There is more to this code but I think these correlate to the options, at least for System Monitor 3.8.2.1 through 3.19.3:
- Stop Process = SIGSTOP (pause signal, let's you continue later with SIGCONT, does not kill process)
- End Process = SIGTERM (termination signal, the right way, the application can intercept this signal and intiate shutdown tasks such as temp file cleanup)
- Kill Process = SIGKILL (kill signal, extreme, only use if SIGTERM doesn't work, won't intiate shutdown tasks)
See this question on Quora about SIGINT, SIGTERM, SIGKILL and SIGSTOP signals for a good explanation on all of the kill/quit/shutdown signals and their differences.
    - 3,928
Per the System Monitor manual, you should normally use "End Process", and only if that fails use "Kill Process":
You usually terminate a process only if you cannot end the process normally as described in To End a Process.
On a technical level this makes me think that End Process sends a SIGQUIT, which allows the process to trap and perform cleanup if needed, but if that fails, Kill Process should send a SIGKILL which should violently terminate the process, without chance of recovery. Use sparingly!
    - 34,802
