First I would like to note, my problem is similar to this but the response didn't work. Unable to sudo apt-get install ubuntu-desktop --reinstall
When I run sudo apt install --reinstall ubuntu-server, I get
Building dependency tree
ubuntu-server : Depends: byobu but it is not going to be installed
Depends: curl but it is not going to be installed
Depends: ubuntu-cloudimage-keyring but it is not going to be installed
Depends: vim
Recommends: lxd but it is not going to be installed
When I try to install these packages, take vim for example, I get
Reading package lists... Done
vim : Depends: vim-common (= 2:7.4.1689-3ubuntu1.4) but 2:8.0.1453-1ubuntu1 is to be installed
If I have apt ignore these dependencies for the reinstallation, will the reinstallation finish? or this Can Not work and Needs to be done manually?
Please let me know if there is anything you would like me to try or clarify.
