Server is setup with the full desktop install of Kubuntu Linux 18.04LTS. I Nginx, and Apache2 installed. I also have Gogs installed. And I have 4 cert's from Let's Encrypt installed.
From a web browser on any of the computers on my LAN (and because I've edited my HOSTS file on them), I can get to any of the 4 web sites on my server using i.e. , , ,
where Domain1 and Domain 2 are served from the Apache2, reverse-proxied from Nginx. Domain3 and Domain4 are served directly from Nginx, with Domain 4 actually serving up the Gogs service. The MyEncrypt stuff all goes through Nginx. It seems to all be working well, except that I can't access any of these 4 domains from the browser on my server. I realize having a browser on a server is a bit unusual, and it is perhaps not a major problem, but shouldn't there be some way to make it work? All I get are timeout errors from it.
I solved the problem I was having, and as usual it turtned out to be something considerably simpler than I'd anticipated. It turns out I had configured the ethernet port incorrectly in Kubuntu's System Settings > Connections GUI. I discovered the problem when I had some issues with apt failing.
The correct settings I needed were: {
Select IPv4 tab.
Set Method: Manual
DNS Servers: 192.168.0.1
Search Domains 8.8.8.8,8.8.4.4
DHCP Client ID: (blank)
Address: 192.168.0.20 (static address on LAN)
Netmask 255.255.255.0
Gateway 192.168.0.1
I found my mistake when I looked at how I had setup a different server on my LAN that was also using Kubuntu 18.04 LTS, and it was working. I've now made a hardcopy of the screenshot so I have a handy reference for the future.
