249
I know how to start a screen, and how to list different screens:
screen -ls
or to attach:
There are screens on:
        2477.pts-0.server1      (Detached)
        2522.pts-0.server1      (Detached)
2 Sockets in /var/run/screen/S-root.
$ screen -r 2477.pts-0.server1
But what is the key combination to detach from a screen session and keep it running?
muru
  • 207,228
maniat1k
  • 8,340
5 Answers5
304
Ctrl+a followed by d. Note the lower case. The [screen manpage] has a long list of these shortcuts under "DEFAULT KEY BINDINGS".
Soren
  • 3,156
80
To list your sessions, run:
screen -list
You can run any command under screen command like:
screen myscript.sh
Then press Ctrl+a (release) and then d to detach the process/screen (so it'll continue to run).
To resume detached process, use:
screen -r
If you have multiple, then add the session number after that.
You can also re-attach to already Attached screen by screen -x. Useful to investigate why it's attached, share terminal with someone or to watch/check somebody what they're doing.
For more help, either run man screen or within the screen press Ctrl+a, release and then hit ? to see more shortcuts.
See also:
kenorb
  • 10,944
16
You'll probably see it listed like this in the screen man page:
^a - d
It's important the note the case of the letters as uppercase and lowercase will do different functions.
rwc
  • 601
11
Create screen using this command: screen -S testscreen
List the screen using this command: screen -ls
Attache the screen using this command: screen -r testscreen
Attache the multipurpose screen using this command (if already others are attached with the same screen): screen -x testscreen
Detach the screen using this command: screen -X detach OR Ctrl+a+d
Kill the screen using this command: screen -XS testscreen kill
Terminate the attached screen using: Ctrl+d
Some systems remove certain bindings by default. So it is best to look at the online keybinding page: Ctrl-a ?. You can also use the command prompt in screen: Ctrl-a :detach. Myself, I generally remove the key bindings for 'detach' and 'powerdetach', except on remote systems.
Arcege
  • 5,618
